F6 Illustrated Build Guide
lhquam,
Does the Wayne BA 2018 Linestage fit the bill?
The Salas DCG-3 and the AKSA-Lender Preamp are two other projects that come to mind.
I considered Wayne BA 2018 Linestage, but it seems like overkill. I haven't recently looked at the others.
I might consider a 1:2 step-up transformer if the F6 wasn't already using transformers which limit then bandwidth and introduce their distortions.
Been running F6 with various pre’s for I’d say 20 cycles @ 4 hours a cycle. I checked bias it was .330 both sides & offset was under .005. Why does the bias drop?? I warmed it up considerably when first built with all sheet metal/case enclosed. I set bias @ .6. Ive reset and staying hooked up to see what transpires. Any thoughts are welcome.
Completed my F6 build today. Got caught on the LED polarity being different on the two boards and also had to follow the change of R7 & R8 to 3.3K and use 6.8 volt zeners. One channel seems more stable on bias than the other, even after an hour so will monitor it. Chassis is one I bought over 10 years ago, EBay I think.
