Amp Camp Pre+Headphone Amp - ACP+
I don’t see any big issues on the board, though I’m no expert. Seems you went with an alternative way of mounting the RCA jacks. Might be worth verifying they’re hooked up correctly. For instance, a few of the ‘G’s’ (ground) in the silkscreen were inadvertently bumped down when the artwork was sent off (or at least I assume that was the case).
Thanks for your advice, I don't think the RCA jacks are mounted falsly.
I notice that you seem to be using Nichicon “Gold” caps for both input and output coupling duties. I did the same, and had the same issue. Swapping the input cap for an Elna Silmic II solved this issue for me, though it’s a tad too smooth for my liking now. I’ll have to see how the sound changes as the cap burns in. Not that I believed in capacitors changing the sound or capacitor burning in until now, but I guess I was wrong.
Thank you very much! That is indeed helpful 🙂 I will definitely check that. Which ones are the input caps, would you tell me please?
put proper size resistor in R13 position - 0207 size, same as you use for R12, for example
there is substantial dissipation for that small one
hum-buzz - confirm PSU voltage
screw thin wire with pot nut and solder wire to closest GND pad, that way you'll get pot case silent
do you have additional under-plate pcb, for shielding?
also, compare voltages across R12 in both channels, write here
Voltage across R12 = 325mV on both sides
underplate pcb => yes, I have one
"screwing thin wire to pot nut and solder it to gnd" by pot nut you mean from one of the 4 nuts that hold the screws in place that connect the pcb to the ground plate => screw wire in one and solder to gnd? Did that but doesn't help with the humming
volume pot nut - it's somewhere 9mm of inner Diameter ...... that's nut for sleeve around pot shaft
that way you're connecting volume pot metal case part to GND , so there can't be buzzing when you touch the shaft
325mV across R12 sez that there is proper 150mA though OS
what is voltage at plus of C3, ref. to GND?
Your front end is starved for current. (due to wide range of variations in J113, yours are low Idss) That may be the issue with your sound.
Place 33R resistor in parallel with R4 (to make ~27R) or replace R4 with 27R.
Thanks for the reply. So in case I have to order some resistors anyways I shall replace R4 with a 27 uF resistor? Or what does R mean here?
use ohmmeter and little thinking to find appropriate GND point
you confirmed two relevant points (Iq, C3+) and they're OK
voltage across R4 is not logical , it's too low
what is origin of your JFets?
JFets are from diyaudio.com, should be fine.
You have a Jfet (J113) providing constant current to your signal/gain jfets (J74’s). 6L6 is suggesting that your constant current jfet (j113) is not providing adequate current to the J74s. Remedy is to lower the resistance from the J113, thus providing more current.
Though I do not understand why this would be I understand what to do now. Thanks again for explaining. So I will get different resistors and see if R4 current then will be closer to 1.2V.
Thanks to all of you for your quick support! It's much appreciated. Once I learn a bit more, I'm sure I will build more Pass stuff 🙂 already super happy with my ACA mono blocks. Next step might be a F5 one day 🙂
