How to - Distortion Measurements with REW
Ok think I'm getting the hang of this now, does this look right for a 1khz loop back on a Motu M2? Cables just jumpered together with crocodile clips at the moment.
I don't know for your interface. For mine the outputs and inputs are servo balanced and can accept mono or balanced. You would need to check the documentation for yours.
Edit: On the Motu website it says "2 x 1/4" TRS line out (balanced, DC coupled)" for the outputs. So looks like balanced for the highest fidelity connection.
Specs | MOTU.com
For the inputs: 2 x XLR/TRS combo inputs
(TRS is again balanced, which is pretty much standard for this level of audio recording interface.)
I still don't think I'm getting the cabling correct, from channel 1 is it balanced or mono out? And for channel 1 in is it balanced or mono?
I just use a 6.5mm TRS cable from output 1 to input 1 and get around 0.0002 THD. One tip I can give you is the gain of the input must be at 0. Any additional gain from the input kills THD and noise performance. I've installed REW and am getting familiar it so will post some s/shots of performance soonish.
I made the cable up a balanced to balanced trs, and took these measurements based on the settings from the last few posts. Looking at the first post it looks like its working well but its not stable see pic 2, any ideas what could be happening?
Your second image looks like the problem I was having with my laptop, REW and Windows 10. (Latency too high resulting in audio drop outs.)
The following helped:
1. Run with realtime priority (see post #734). [Most important improvement.]
2. Turn off WiFi on the laptop during measurements.
3. Close every other other program.
4. Run 44.1k or 48k on a slower/older laptop.
My older desktop (which uses Windows Vista) still runs REW more reliably than my Windows 10 laptop using REW.
You can also look at post #704 for diagnosing the problem with Latency Monitor:
Thanks Jan. On the issue of dropouts, LatencyMon is a good tool to identify problematic drivers or processes that may be causing audio issues. I've seen reports of issues with the Win 10 20H2 update for some users with USB interfaces, driver updates may help in those cases.
Thanks for that, it made a slight difference not much. I'll look into latency monitor see if that points to something.
This is the best I can get out of the Motu loop back, and self noise to compare with others.
MOTU M2/4 use USB-audio asynchronous mode with implicit feedback. The implicit feedback is unsupported (i.e. ignored) by stock USB audio class 2 win10 drivers. The result are typically dropouts because capture runs at a different speed than playback. Do you use drivers supplied with Motu or stock windows USB-audio drivers?
