Acoustic Horn Design – The Easy Way (Ath4)
TNT what mabat is showing is how well the termination works in guiding waves from both directions.
With the 180 termination when sound comes from behind less of it makes it's way to the front because of the termination, just the same as when viewing the termination from the front less sound wraps around the back.
But I cant understand how a wave can come from behind in free field.
fluid, in your simulation I can understand it as ther is in fact something behind - a reflector as well as an exciter to interfere with,
I think that is where your confusion is coming from. You are right that in a free field there won't be a wave from behind unless there is there is a source behind the guide.
But in reality sound will come from all directions once it has been released into a room due to reflection and diffraction from various surfaces.
Sometimes in a simulation something that would not exist in reality has to be used to demonstrate the principle.
Actually, there is a source behind the guide even if there's no wall. Many small sources, in fact, at all the points where diffractions occur. For example at the very back of the waveguide body. And that's just one of many.
The directivity of all this will be stupendously complex but it's almost certain that some of the waves on some frequencies will be directed at the mouth edge again.
Hopefully I will have measurements soon 🙂
- As for the previous debate, maybe the best way to look at what diffracts back from the rear side of the waveguide would be via time windowing of the impulse response at the late enough time interval, excluding the direct sound and the first edge reflection. Or some spectral-time analysis - I've never done this much so this may be a good opportunity to try.
Iwata 300 print TPU65D - low resonance low decay, low weight, 16mm wall.
Somebody said source behind wave guide?
International
