The TD-2001 could work (slightly) better with a higher value of k > a less abrupt opening.
I'm about to order the big sand-printed Faital Waveguides, ⌀494 x 192 mm. The quote is 1150 EUR/pair. Should anyone be interested, please write me aside.
Guess; density = 1,5 => 7kg?
Exiting and I think I can feel your level of anticipation. So what will the waiting time be once you push the button?
What considerations have you done with regards to how the woofer cabinet should look? It's a difficult design to get to look pleasing.
I don't think it's that difficult. As the waveguide will be the prominent feature anything unobtrusive will do. One of the ideas is not to use any woofer cabinet at all.
BTW, in Ath such a throat extension can be added simply like this (that's what I did above):
Throat.Ext.Length = 65 ; [mm]
Throat.Ext.Angle = 3.6 ; [deg]
Thanks Marcel, I'll play around with it. Which of the demo#.cfg's that is close to the ST260 design, that would be a good starting point for tweaking?
How about IB, in the floor?OB or Horn Loaded?? don't keep us in suspense!
Sorry I just started learning ATH. I'm looking at the cfg files, I only see term.s/n/q don't see k values. Can you please help point out where I could increase the value of K?
The final model of the smaller one (1", ⌀336 x 184 mm). This is 450 EUR/pair.
This one's for the HF108?
Is it possible to order this in an unfinished / rough surface (non-glossy)?
- Acoustic Horn Design – The Easy Way (Ath4)
