Hello,
Some threads and mulitple users mentionned the high sound quality of the TPA3221 (Texas instrument).
Main advantages over TPA3251 or TPA3255 are :
- build in or external LDO
- differential or single ended input (no need for an opamp !)
I have seen this one : Nosound Super Mini HiFi TPA3221| AliExpress
There is no on/off switch which may be a problem... is it click and pop free ?
There is another one - bare board
TPA3221 Module de carte amplificateur de puissance numerique Cl D 100W + 100W amplificateur haute puissance | AliExpress
I believe the TPA3220 is from the same family.
The evaluation board for the TPA3220 is the cheapest Ti offers.
If I´d be in the market for a multi-channel class-d-amp I´d get 2-3 of these.
I just found other good suff
https://shopee.vn/Mạch-Tpa3221-D2-100*2-bluetooth-QCC3008-i.22247221.4261397280
https://shopee.vn/Mạch-công-suất-Class-D-TPA3221-(100W*2)-i.36282148.3869099150
https://shopee.vn/Bo-mạch-khuếch-đạ...số-TPA3221-HD-2-*-100W-i.127503828.7964213329
But unfortunately the are not sold on ALI or Ebay :-/
Did you try some of these boards?no preamplifier> low input impedance> little bass> noise
Your board's inputs may have been configured for high gain, and low input impedance. Refer TPA3221 datasheet, page 23.low input impedance> little bass> noise
The upper limit of input gain is 34 dB, and at this setting the input impedance is just 7.7 kohm. But if you set the gain to the minimum of 18 dB, the input impedance is then 48 kohm.
Input gain is set by the values of R1 and R2, see page 19.
that's what I wrote about .... I don't see a pre-amplifier, I suspect that there is no external pre-amplifier
I assume that the maximum gain is set, with consequences for the quality
Yes, hooray! That let's us choose our own pre-amplification choice, or no preamp if the output stage of our DAC has suitable gain and output impedance.I suspect that there is no external pre-amplifier
Yes, but it's been the same situation with TPA3116/3118 amp boards for several years now - the popular Sanwu TPA3118 board is configured with a high gain of 32 dB, and to get best quality from this board you should modify it to reduce the gain to 20 dB.I assume that the maximum gain is set, with consequences for the quality
Good news Guys.
Tpa3221 can now be bought from AliExpress with qc3008 Bluetooth modul.
I ordered one
Will test it when I get it :-D
Looks good.
I ordered one
Looks good.
hello guys. I just received the amp. Really good. Components looks to be original.
Gain is only 24db. Because the input is directly connected to the QC3008 the max volume is not very high.
When no music is played the amp is silent dead no noise or others. Bluetooth connection is APT-X.
I see you are running it powered by a battery. What about connecting a PSU? will noise appear?the amp is silent dead no noise or others
Intrigued by the less flattering statements about the TPA3221, I bought this well-priced board: TPA3221 Module de carte amplificateur de puissance numerique classe D 100W + 100W amplificateur haute puissance | AliExpress . No BlueTooth.
I only gave it a very brief test with 19Vdc supply and mediocre speakers. It worked, I noticed no hum or hiss. A good "click" at start-up.
Visual inspection did not reveal anything upsetting. One 8-pin SOT-package IC had its identification marking removed. My first impression is that it is not a double OP-AMP but rather something relating to start-up.
It could be a good choice in-between TPA3116 and TPA325x, and with a seemingly correct price-tag. A competitor to TDA7498E and TDA8954TH. I will perform more thorough tests later and probably draw up the schematics.
I'm surprised you heard a click at start-up. The engineers at TI are pretty serious about absence of start/stop noises. When I worked there, I had to do design revisions because there was still a little bit of audible pop.
I understand your comment. Most frequently it is at switch-off. I tried more times to be sure. Could relate to the board implementation.
I worked on smaller class D ICs for our television manufacturing customers. They demanded inaudible start/stop (or a big discount!). I suspected they would rather have the discount, but we gave them inaudible start/stop.
For the home hi-fi and guitar amp market, a tiny click is probably considered OK. I miss amplifiers having a small tick or thump at startup to let me know they are on. I left TI back in 2012, so I did not work on any of the current chips.
Maybe some mute switch solve this... I bought this well-priced board: TPA3221 Module de carte amplificateur de puissance numerique classe D 100W + 100W amplificateur haute puissance | AliExpress . ...A good "click" at start-up...
- Class D
- TPA3221
