Pictures of your diy Pass amplifier
I agree with Zen, a surrounding case with shielding properties is not necessarily required (though proper grounding recommended) - My “exoskeleton” Aleph 3 build serves as one example...
that's damn Fugly!
:clown:
just one thing - when Big Donut is not surrounded with big Faraday Case, it'll maybe result in need of greater clearance to surrounding apparatuses ........ (sources,preamps)
but , that's manageable
I haven't had much time to listen nor compare the sound, I'm currently driving my pair of ACA amps in balanced mode. I plan on "testing" the preamp for a month before I install it in the primary system with the Aleph J.
Since I removed the BZLS driving the ACA's, the BA2018 does not have the gain, yet it has a softness to the sound in comparison to the BZLS.
I need to spend time with a turntable connected to make sure the UFSP to make sure everything is good.
I'm very curious to compare the BZLS, the B1 Korg balanced line stage and the BA2018 with the Aleph J.
Then compare the B1 Korg, the BZLS and the BA2018 with the M2X.
I have a note pad next to my chair to record thoughts during the comparison. I'll post the results in the future.
I would like to thank mareli for his diagram to wire the inputs on post #1991 on the BA2018 thread.
Folks:
This could have been completed in 2020, but I built plenty last year; better to start off the New Year with something fun.
Scott
