I bought a DAC with a balanced output. Made with PCM5242.
For testing TPA325x with balanced input.
Interesting! I'm about to buy a Topping E30 but if your amp sounds better with a balanced dac I can change my mind.
I look forward to hearing from you
Will you be using it to test the group of boards you are finishing now (includes mine)? I ask because I will be using your amps with balanced inputs.
Thanks,
Rod
I bought for this.Will you be using it to test the group of boards you are finishing now (includes mine)? I ask because I will be using your amps with balanced inputs.
I bought for this.
It would be interesting to know your opinion of any sound differences between balanced and single ended inputs as you do you testing. Thanks.
I intend to use it with balanced inputs. Having SE preamp outputs though, will use this SE to Bal converter: SparkFun THAT 1646 OutSmarts Breakout - BOB-14003 - SparkFun Electronics
When I got my Scarlett Solo which is balanced it sounded better than my Khadas Tone Board to my ears. The bass and mid improved.
I also have this HiFiBerry DAC+ Pro XLR which I have not tested yet as I need to make some leads, it plugs into a RaspberryPi. It cost £55. It did not test that well, worse than the Solo.
The Audiophonics DAC for my AllInOne amp tests well, it has SE and balanced outputs so I will be able to compare them.
Hi DrMordor,
I see that group buy is closed. Any chance, I can get a one? Or in next group purchase? Any idea, when would be the next group purchase coming?
Thanks,
Simar
Thanks,
Simar
I invite anybody late for the group buy to contact me. I will trade mine so that you'll receive it directly from Dr. Mordor.
Meanwhile i got the stickers done (blackboard)
Enjoy...
Compliments!
what speakers are you using?
Enjoy...
Hi! It's 19 inch rack ... what are you going to do with the available space? 😎
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
