Xmas Amp - Dibya's TDA7293 by Jhofland
Founder of XSA-Labs
Joined 2012
No worries, there were a few who were asking if spots available.
MaxReboBand / 2 boards / USA
as8912 / 2 boards / USA
ahtllc / 2 boards / USA
dBel84 / 2 boards / USA *Cancelled *
Flamethrower1 /2 boards/ USA
Signal Lost / 2 boards / USA
diy.tiger / 2 boards / NZ
MShipmanPE/ 2 boards / USA
Angchuck / 2 boards / Singapore
Francois G / 2 boards / USA
Asuslover /2 boards /USA
Guerilla / 2 boards /Denmark * cancelled*
astromo / 2 boards / Australia
Kay Pirinha / 2 boards / Germany
pinkfloyd4ever/ 2 boards / USA * cancelled *
Sixto / 2 boards / USA
Tubesguy / 2 boards / USA
E_Fortier / 2 boards / Canada * cancelled *
Hicoco / 2 boards / France
Liva / 2 boards / Canada * cancelled *
Kokanee / 2 boards / Canada
chermann/ 2 boards / Austria
twocents/ 2 boards / USA
s610adam / 2 boards / USA
hochopeper/ 2 boards / Australia
1883 / 2 boards / USA *Canvelled*
Jlevro / 2 boards / USA
nautibuoy / 2 boards / UK
Whoever needs boards, add your name. Plenty available now. 3 more sets available now.
yay! I thought I'd missed out. I'm a big fan of the 7293 chips.
invaderzim / 2 boards / USA
kp93300/ 2 boards/ Malaysia
Founder of XSA-Labs
Joined 2012
Great to see more interest.
We have good news to report. After some debugging and Jhofland ran some simulations of the DC servo, we found that by replacing R115 with a 47k ohm resistor, the DC servo works now with less than 5mV offset. So now, we have eliminated the electrolytic cap in the negative feedback path. Hopefully this translates to deeper bass.
attachment.php
Waiting list addition
Legis31/ 2 boards/ usa
Waiting list addition.
Panellists/ 2 boards/ USA
Please ignore Panelists. Typo by auto spell. I apologize. Should be..
Pandpliers/ 2 boards/ USA
I think this is how it looks:
comicrcc / 2 boards / USA
Waiting List:
Waiting List:
DarpMalone / 2 Boards / Canada
Founder of XSA-Labs
Joined 2012
More great progress from Vunce. The verification build is now playing in stereo in the donor chassis. Source is AD1862 DAC, Yarra with ACP+ as preamp, TDA7293 amp with All Cee’s PSU loaded with 4x 10,000uF caps and 300w 25v trafo, and 10F/RS225 FAST TL’s speakers. So far everything plays and sounds quiet (no hum). One note: the mounting screws for the TDA7293 boards need to be insulated as the ground plane currently extends all the way to the edge. One of them has a ground loop breaker but the others do not. We will need to modify the final layout to have the remaining 3 holes electrically isolated from ground to avoid hum and ground loops.
So the only required mod for now with respect the components is the use a value from 10k to 47k for R15 to get the DC servo to work properly. With 47k we are getting about 4mV DC offset. The optional zener diode opamp power supply mod has been tested and works. Only needed if you plan to use power supplies > 40Vdc.
attachment.php
Founder of XSA-Labs
Joined 2012
I just finished building my Xmas TDA7293 amp. I still need to drill and tap an M3 screw thread on the CPU cooler heaatsink. Will do that tomorrow and connect to my +/-37.4v PSU. I am using some 5uF polycarbonate input caps. I am using the DC servo with a 47k value for R15 (as tested by Vunce).
attachment.php
attachment.php
attachment.php
Joined 2014
Nice X! A lot sexier (with those fancy green inductors) than Vunce's build, which seem to be missing some components. :D
Waiting in anticipation for listening impressions...
Yeah, my inductors are not up to my standards, I had to re-form existing pieces.
All parts necessary are populated on my boards, the “missing” pieces are because the HV dc servo psu is configured differently than using the LM317/337 regulators.
