SMD LT4320 rectifier - 2 USD per pair.
THT LT4320 rectifier - 3.5 USD per pair
CRC PSU PCB with LT4320 - 6.5 per piece
Thanks for prompt reply. I am going to place order as following, where could I input my info? or just PM you directly?
SMD LT4320 rectifier - 2 USD per pair x4
THT LT4320 rectifier - 3.5 USD per pair x2
CRC PSU PCB with LT4320 - 6.5 per piece x2
which ones did you get?
i have both smd and tht versions of pcbs.
if your pcb is smd, then pl refer schematic below for smd mosfet options
LT4320 based active rectifier
nearly 3000 pcs available on farnell.
http://www.farnell.com/datasheets/3006523.pdf
Hi Prasi,
I sent you PM to update my order again, please check and Paypal my bill , thanks
CK
CK
hi ck,
i have sent you the paypal invoiice for 5x smd, 2x tht and 4x upc 1237 protection.
pl check and let me know if you havent received it.
i have noted down your new postal address..
regards
prasi
regards
prasi
Hi Prasi, is it possible for me to have a tracking number for the shipment? Thank you!
Gaetano.
Gaetano.
hi ghitus and ckwong99,
i will send you tracking number as soon as i ship.
sorry i have been bit busy with work so wasnt able to ship.
regards
prasi
regards
prasi
Thank you very much Prasi! One question: having a look at the 3D model of the THT rectifier, I noted the presence of some SMD components on the back side of the PCB. Do the PCB come with those components already soldered? Does the BOM in the OP refer to the THT rectifier? On its back side I see a big resistors which isn't present in the BOM. Can you give me some clarifications?
Thank you,
Gaetano.
Thank you,
Gaetano.
Those smd components are the optional quasimodo snubbers that you can do without.
Simple, no-math transformer snubber using Quasimodo test-jig
the big THT resistor on bottom is for the led . you can calculate based on your voltage. this is also optional. (V-Vfled)/Iled. you can keep Iled to 2-5 mA
- Group Buys
- LT4320 based active rectifier
