Apex A40 fundamental improvement. (Sandy)
Comparing diode of Zener and 1n4148
With 2×3.3 ohms this is current of the diodes in red 1n4148.
and with 2×5.5 ohms for 1n4148
Are these diodes following in temperature the output transistors?
Try to think again about what will happen when the final transistors heat up.
They are on the heatsink and the diodes on the board.
By heating the radiator, the thermal compensation circuit will reduce the base / emitter voltage and therefore the voltage across the diodes, and the current through the diodes will decrease even more.
