My DAC is using a double linear PSU (very well insulated), one PSU per AK4497 chip and absolutely well designed, the DAC is fully symmetrical.
With this AC / High frequencies filter it is better now regarding Drmordor module.
In front of the power supply of the dac I put a TNT-TTS self-made power cable, it sounds better
The TNT - TTS DIY mains cable
Just pushed the button on Topping D90 - its is reported as having better soundstage than the SMSL. All being well will be with me next week - I'll compare against my T+A DAC 8 DSD (which I found to perform very close to the Mola Mola Tambaqui when I tested them together - T+A running DSD).
Cheers
Oh, in Europe Topping is €120 cheaper than SMSL M400. They are too close in quality, I would go with Topping too.
I hope you will like the sound and please report OK?
Try it with a good cable and let us know 🙂nerone, the TTS mains cable caught my attention.
I have a diy audio usb isolator (because when i turn the light tube neon ...the dac lost the signal...)and the dac double ak 4497 is recognized, every other time by the pc... but with the smsl m300 no problem...whithout isolator :confus:
Awaiting your test results!Hi amigos,
Got last TPA3255 by 3E Audio. (8 Ohms version with 44V PSU)
Here some pictures so you can have an idea about its size VS AIYIMA TPA3251 VS DrMordor TPA3255
I did not test it yet...
But at first sight + and - :
- Seems well made and solid, compact if you consider the integrated PSU ++
- Elna Audio Grade caps for buffer ++
- OP amps DIP8 Socket ++ (update OPA1602 in pictures with a copper film)
- Anti Pop protection ++
- Chengx Power caps -- (4x1000uf)
- Noiseless Fan +- (useful ?)
- CODA inductors (not sure about this, unmarked ?) --
- QC3008 Aptx BT chip ++
- No power cord provided --
- Quasi resonant PSU ++
Next step : Audio test VS DrMordor VS Aiyima A04 (Tilear Rev 2.1)
In the 21st century, the DAC no longer plays a special role ... Alas and ah ...SMSL M400 review:
SMSL M400 Balanced USB MQA DAC Review | Audio Science Review (ASR) Forum
The measured performance is nothing short of world class. USB output quality is near to perfection. That is importante mucho mas senior.
I use a simple, Amanero company ...
This is more than enough ...
Absolutely not true - Purifi is my best amp so far. Sounds better than LM3886 and would you believe an EAR861.
mplifiers cannot "sound" by definition ... 🙂 It's like a battery - when you turn it on, it's warm, when you turn it off, it's cold ... It shouldn't be visible, but it should be warm.
The amplifier should not distort the original signal ... That's it ... 🙂 All your suggestions about the upgrade are a bluff .. If the speaker system gives more than 1% distortion, then it doesn't matter what kind of distortion your amplifier gives ... 0.1% or 0.5% ... I like reading fairy tales from Muscovy ... 🙂
Never, ever put a SMPS, DAC or PC into your stereo mains supply without mains filter. Cos the rest of the equipment will suffer for sure.
The best you can do without paying too much:
1st mains filter->1st isolating transformer->DAC
2nd mains filter->2nd isolating transformer->Anolgue equpiment (preamp, tuner, phono pre etc.)
->mains filter (after the 2nd isolating trans)->SMPS of power amp
The ravings of a crazy audiophile ... 🙂
Here my quick review after a 3 days listening test.
VS DrMordor Module :
- 3E Audio With OPA1612 sounds great and still have a good sounstage. But
it definitely lacks consistency in the sound compared to the Drmordor module. The Drmordor is much more dynamic, more "organic". The bass drops lower and medium + high are better as well. Regarding the soundstage, the amps are equal, it is very precise and we find "the signature of the TPA3255" which remains, to my ears, the most holographic chip on the market. Regarding the quality of the case, and its fan, the 3E Audio is really well made, the fan is pretty noiseless, can't ear it at all.
Another important point, the Drmodor is more powerful at equal volume ... PFFB + best PSU (LLC) on DrMordor make the difference....
VS AIYIMA A04 (black PCB Tilear 2.1 with OPA1656)
- concerning the overall listening, I think that we are rather on amps of the same range, I found the 3E Audio a little less "alive" than my AIYIMA but I think that the OPA1656 are there for something (I did not test the 3E Audio + OPA1656). They perform almost equally but the AIYIMA is using a TPA3251 chip, so it's not necessarily very comparable.
On the other hand, I found the AIYIMA quieter, especially when I stream in BT (APTX HD via my DAC), it is less sensitive to interferences, it does better than Drmodor and 3E Audio in this regard.
Conclusion :
For less than $100, the 3E Audio TPA3255 is good amplifier, well made, well designed and interesting overall.
If you are really looking for the rolls of the TPA3255, go for a Drmodor, a Jlester or even an XRK Audio, we know why we pay more for them)
We do not play in the same class!
Conclusion :
Complete nonsense ...
I use two such amplifiers: https://www.amazon.com/Amplifier-TPA3255-4-Sound-High-Power-Speakers/dp/B08D7QL9MW less than 50 USD
Two microcircuits on one board ... Four BTL channels.
Acoustics three-way, one amplifier per speaker
different frequency ranges.
It is possible to use these amplifiers for a four-way speaker system ...
Powered by MW 200-36. This is more than enough.
After Amanero, the signal is split into three bands through the Behringer DCX 2496.
Take a look @ ASR / Dac performance index.... you will be surprised )
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
