SMSL M400 review:
SMSL M400 Balanced USB MQA DAC Review | Audio Science Review (ASR) Forum
The measured performance is nothing short of world class. USB output quality is near to perfection. That is importante mucho mas senior.
I will be able to add another opinion shortly. My Purifi's run the neurochrome buffer / hypex HxR's.
Should be fine, but this only makes sens if you have a high end TPA3255 module... not a "chinese" one with bad caps etc...
A good TPA3255 amp makes all the difference. When I mean a good one = DrMordor / XRK Audio / 360 Customs / Jlester I dont include 3E Audio here.
True, my Chinese TPA-3255 was on the edge of unbearable to put it diplomatically. After the mods it sounds better than 300B monoblocks, Accuphase, Sansui, Marantz, Sony, KT-88 Push-Pull etc.
As we discussed with cdsgames, a TPA3255 with an implementation worthy of the name, can bring a Purifi or a Bosc to its knees. You will see it soon )
A good TPA3255 amp makes all the difference. When I mean a good one I dont include 3E Audio here.
How come? What can be made better?
Of course - I have the Jlester modules. They're really well done.
First batch or last release with PFFB ? First version is not so good...
I own many TPA3255, including 3E Audio (finished amp + modules) and the Drmordor is far away better !
Well, after bringing down my Accuphase power amps and my 300B monoblocks nothing surprises me. Thanks god that there is a company like Texas Instruments. YEE-HAW!
Listening test Accuphase P-300X (rewired, recapped & aligned) vs Chinese TPA-3255 (modded) with Meanwell PSU (modded).
Transient response:
Accuphase P-300X =
TPA-3255 = Rocket
Transparency:
Accuphase P-300X =
TPA-3255 = Sunshine
Of course! It is made in Russia!
Thanks,
If you had to invest :
SMSLM400 + 3E Audio TPA3255 or TOPPING DX3 Pro + Purifi / Bosc ?
Just pushed the button on Topping D90 - its is reported as having better soundstage than the SMSL. All being well will be with me next week - I'll compare against my T+A DAC 8 DSD (which I found to perform very close to the Mola Mola Tambaqui when I tested them together - T+A running DSD).
Cheers
A German friend of mine just told me that the ICEpower125ASX2 sounds galaxies better than Purifi. He said the Purifi is plain bad, cos sterile & cold & emotionless reproduction.
Absolutely not true - Purifi is my best amp so far. Sounds better than LM3886 and would you believe an EAR861.
Nice, good to know ) Let me know VS Purifi asap )
LOL I have to admit the Russians work well)
Never, ever put a SMPS, DAC or PC into your stereo mains supply without mains filter. Cos the rest of the equipment will suffer for sure.
The best you can do without paying too much:
1st mains filter->1st isolating transformer->DAC
2nd mains filter->2nd isolating transformer->Anolgue equpiment (preamp, tuner, phono pre etc.)
->mains filter (after the 2nd isolating trans)->SMPS of power amp
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
