A German friend of mine just told me that the ICEpower125ASX2 sounds galaxies better than Purifi. He said the Purifi is plain bad, cos sterile & cold & emotionless reproduction. 😕
SMSL M400 review:
SMSL M400 Balanced USB MQA DAC Review | Audio Science Review (ASR) Forum
The measured performance is nothing short of world class. USB output quality is near to perfection. That is importante mucho mas senior.
I will be able to add another opinion shortly. My Purifi's run the neurochrome buffer / hypex HxR's.
Should be fine, but this only makes sens if you have a high end TPA3255 module... not a "chinese" one with bad caps etc...
A good TPA3255 amp makes all the difference. When I mean a good one = DrMordor / XRK Audio / 360 Customs / Jlester I dont include 3E Audio here.
True, my Chinese TPA-3255 was on the edge of unbearable to put it diplomatically. After the mods it sounds better than 300B monoblocks, Accuphase, Sansui, Marantz, Sony, KT-88 Push-Pull etc.
As we discussed with cdsgames, a TPA3255 with an implementation worthy of the name, can bring a Purifi or a Bosc to its knees. You will see it soon )
A good TPA3255 amp makes all the difference. When I mean a good one I dont include 3E Audio here.
How come? What can be made better?
Of course - I have the Jlester modules. They're really well done.
First batch or last release with PFFB ? First version is not so good...
I own many TPA3255, including 3E Audio (finished amp + modules) and the Drmordor is far away better !
Well, after bringing down my Accuphase power amps and my 300B monoblocks nothing surprises me. Thanks god that there is a company like Texas Instruments. YEE-HAW!
Listening test Accuphase P-300X (rewired, recapped & aligned) vs Chinese TPA-3255 (modded) with Meanwell PSU (modded).
Transient response:
Accuphase P-300X =
TPA-3255 = Rocket
Transparency:
Accuphase P-300X =
TPA-3255 = Sunshine
Of course! It is made in Russia! 😉
Thanks,
If you had to invest :
SMSLM400 + 3E Audio TPA3255 or TOPPING DX3 Pro + Purifi / Bosc ?
Just pushed the button on Topping D90 - its is reported as having better soundstage than the SMSL. All being well will be with me next week - I'll compare against my T+A DAC 8 DSD (which I found to perform very close to the Mola Mola Tambaqui when I tested them together - T+A running DSD).
Cheers
Absolutely not true - Purifi is my best amp so far. Sounds better than LM3886 and would you believe an EAR861.
SMSL M400 is reported to sound warmer. As always measured data of SMSL is better than Topping but not by much. I would go with SMSL. Topping has 4 LME49720 opamps installed - I don't like these opamps.
Nice, good to know ) Let me know VS Purifi asap )
LOL I have to admit the Russians work well)
Just to share,
I added this filter to my DrMordor amp. This helps to avoid RFI / RMI disturbances.
Never, ever put a SMPS, DAC or PC into your stereo mains supply without mains filter. Cos the rest of the equipment will suffer for sure.
The best you can do without paying too much:
1st mains filter->1st isolating transformer->DAC
2nd mains filter->2nd isolating transformer->Anolgue equpiment (preamp, tuner, phono pre etc.)
->mains filter (after the 2nd isolating trans)->SMPS of power amp
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
