Acoustic Horn Design – The Easy Way (Ath4)
Of course they have different weights in the calculation, proportionately to the area they represent, that's the essence of it. The beauty of axial symmetry is that this can be calculated very easily just from one set of polars.
Yes, you're right. I found the post that started my thinking and can see where I got of track:
I thought about the error function criteria for the optimization algorithm a bit. Maybe I would define a target DI curve and evaluate the error function as the residual sum of squares between the target and an average DI curve calculated for a selected listening window (not necessarily containing the on-axis response). Maybe this all weighted with frequency somehow.
What i really notet was the "selected listening window". Perhaps you could elaborate?
Some thoughts: Clearly one wants the optimization to be weighted towards the listening window (in terms of smoothness i supose) but a hard limit can't be good can it? I worry if the optimization might just push response problems outside of this window if made too narrow.
I might be out of my depth on this topic, but i think the optimization is a powerfull tool with many interesting variables and just wanted to incourage further investigation.
- could you just keep the rollover rolling to close the "ball"? That would I think be interesting to see.
attachment.php
The raw shape "DE7" (just added thickness):
attachment.php
Closed-back:
attachment.php
Differences between the axial DIs:
attachment.php
It's hard to foresee all that could happen but once you reach a target of a flat and smooth DI, you can be sure that the direct sound (being it a selected angle or some average over a listening window) will track the power response closely, i.e. it will be possible to EQ for a flat and smooth overall response in the end. That's the rationale behind that.
