Pictures of your diy Pass amplifier
Threshold stasis-3
this is my clone...
Manniraj, are those rcore transformers reputed to be as good as the ones made by Shilchar? Could you post a link where you bought these from?
Thanks.
nash
I am not sure how they compare to Shilchar as never tried Shilchar as they usually sell commercially. I got these rcores from another manufacturer based out of Chennai, India. You can reach them at https://www.indiamart.com/precisiontransformers/about-us.html or on mobile +91 9962848027.
How are the meters connected to the amp?
Right now not connected as the VU meter driver board works with 6-12VAC or DC. And I do not want to use another transformer so planning to make a bread board and take one of the windings from the 23v trafo and drop it to 12v. Was thinking to run the signal from the input RCA jacks as the ACP works either with HPs or line stage and not both at least on my boards where there is a relay (Nisbeth's boards). So cannot use the output signal to the meters and the only way is to use the incoming input signal.
