What do you mean by pads might ? on the PCB ? yes
If there is any kind of short between gate and drain of the jfet eg a solder bridge across the pads on the pcb, then they will certainly burn up
Good evening,
I put the JFET back in place, it continues to smoke:
- G / S 2,7v
- G / D 2,7v
- D / S 6v
I always remain septic about my rail voltage, the JFETs are sensitive (according to Mr PASS) and the TOSHIBA are given for 25v.
And I don't think my JFETs are TOSHIBA.
I measured my JFETs again, I must be around 9mA under a voltage of 25v, so we are still far from the 0.4w dissipation.
- G / S 2,7v
- G / D 2,7v
- D / S 6v
Good evening,
- G / S 2,7v
- G / D 2,7v
- D / S 6v
Out of curiosity, can you post a photo of the JFets? I vaguely recall that simple VGS is not enough but rather, the tests i've seen to confirm fakes is by charting the curves from varying voltages and current?
Hello,
here are the values measured on the PCB:
(I added the polarity, knowing that the negative of the voltmeter is placed on the Gate and the 0v.)
- G / S + 2,9v
- G / D - 2,9v
- 0v / S - 18,5v
- 0v / D - 24,5v
It is also useful to point out that the trimpots are at their lowest.
@ Super BQ: attached the photo of a JFET
On the photo it's GR, but I also have BL, the case is identical and the typography too.
- G / S + 2,9v
- G / D - 2,9v
- 0v / S - 18,5v
- 0v / D - 24,5v
I think, this JFETS are not "B" Grade.. and honestly, they don't look to be genuine..
I bought genuine Toshiba's from ebay seller punkydawgs (smbd here recommended this seller).
Toshiba 2SJ74 + 2SK170 LAB MATCH QUAD to 0.03mA & 4mV (9-10mA range "BL" "B") | eBay
I eliminate step by step to see where this tension comes from.
I started by rectifying the DC voltage with the Trimpot OFFSET, then I separated the positive circuit by removing the 2SK170 first, then R4 and R1.
View the photo
Quel serait la suite logique selon vous ?
View the photo
Continued my inspection, removed the IRFPs, removed all the links that could raise a voltage at the terminal of OUT, NOKAnglais
The JFET must be totally HS, disassemble the JFET, replace with another, I get:
0v / D -26.4v normal
0v / G -14.6v
0v / S -25v
Here is what remains of the circuit and always this tension.
0v / G -14.6v
0v / S -25v
- F6 Illustrated Build Guide
