Unusual amp from 1987
"It doesn't make much sense to use single transistor input (why? to save 50 cents over op-amp?),
and then put op-amp as a servo..."
This structure gives great room for creativity, including applying singleton input. Someone prefer the sound of single tranistor over LTP and opamp, this is why I mentioned that. Two drawbacks need to be solved: low PSRR and offset fluctuations.
Joined 2014
Here is sim file for Lomakin/Parshin + LatFets from post #358
Very simple amp - at the cost of LatFets from Exicon.
I happen to have a stash of ECW20N20/ECW20P20 - dual die Exicon Latfets, rated at 200W each (at 25 degrees).
So I guess just 1 pair of these devices should be good for an honest 100W amp, given that proper cooling is used.
  • radio_1987_09_latfet.asc
  • ecw20n20.pdf
Joined 2014
Maxim, are you saying, LMK amp as described in Radio magazine (as in build from post #87), DOES need this emitter repeater?
If, as you say, output DC voltage on the op-amp is "skewed", what problems it is going to cause?
I don't see why this LMK amp (with latfets) would have better simulated results than Wiederhold amp?
What is 'correct' DC voltage at the output of the amp?
What is 'skewed' DC voltage at the output of the amp?
The one I built (LMK) has 1.1 V at the output of the opamp.
Wiederhold I built, has -1.56 V at the output of the opamp.
In those ancient times, the output stages oramp were mostly low-power and with very low quiescent current, so due to the skew of the ramps, the operational amplifier switched to single-stroke amplification mode.And with a modern oramp, why do you need a constant voltage at the output ?
It will be even better. Anti-clip at least a decent make, and then in the clip at the output of the OU is a very large signal.
Here is a picture, an illustration.
This is the effect of nested OOS.
Anti-clip operation
