Photo Gallery
Here's my home spun 211
My 211 amp, and another project - bringing back to life an old Sp8, that hums and hisses but still sings 🙂
Who makes those transformers? Looks like you need a gantry crane to move that amp.
I designed it, and laid it out got the chassis built from 2000 year old bog oak, designed and machined the 15mm plates for the transformers and got the copper chassis plates made......I did not in the end do the assembly....I ran out of talent and knowledge at that point 20 years ago actually! The transformers and the parts all came from a friend who build valve amplifiers and he ended up finishing it off. It was originally going to follow the kondo ongaku...but ended up a frankenstein of my friends design and kondo...
The transformers were too large and heavy for my friend to commercially use and so I had them.
The whole amp weighs about 65Kg.....and yes it is on a wall shelf!!
I just finished building my Bottlehead Moreplay preamp. It uses a single 6V6 tube wired as a triode and features three pairs of inputs, three position selector switch and two pairs of outputs.
