Did someone already build something with this driver? It took my attention also when they were announced a year ago or so and they finally (thanks covid for the delay) came availeble in my region so i ordered a pair. I'll probally design an own enclosure but i was wondering if someone did already do something with it and what their impression was.
Specs and graphs that are published promise a lot i have to say, and my first sims also. I'm thinking to make a 40L ported cabinet tuned to 38Hz with it after simulating some options. If the data is correct this could be a deal breaker at 60€ for such an 8"(actually a 6.5" if you distract the bezel) i think...
Despite probably being put into Joan, I have a pair in my FHXL, just need to find someone to hump themupstairs so i can listen to them.
dave
dave
What happen to Joan, did anyone of beta builders post anything? I have some Sota11R (probably variation of CHN110 drivers), would Joan be better box for them than FHXL?
The boxes for CHN110 will be MUCH larger than for the P11.
I expect that 25-35 Hz F10 is doable with this driver in the right horn or TL.
Optimal reflex seems to 20-30 litres and can reach low 30s-40s F10. Low 40s-50s F6.
Based on reflex sims it gets to within 5 Hz of the A12pw.
dave
dave
Some of the the boxes I did are on the MA site: https://www.markaudio.com/wp-content/uploads/2019/12/CHN110-detail-box-plans.pdf
A few extras attached here:
just need to find someone to hump them upstairs so i can listen to them.
I can come up tomorrow and give you a hand. What time?
jeff
that is also what i think, altough i think you can tune it to 39Hz and got a response to F3 of 35Hz and an F6 of 32Hz, but that only in a 40L reflex.
That is a lot bigger than my Mark Audio Alpair 10.3 desktop speakers in my office that get a similar response in a 17.9L reflex. But that driver costs a lot more of course. I paid when i bought them a few years ago about 140€, while i paid 60€ for the CHN110's...
In a waw alignment you can have a good flat response to 100Hz in a 5 to 15L sealed. But then you need a subwoofer below that.
I'm not so for TL's. I know what they can do, but they don't do it for me. Idem with BLH's or similar alignments. The bass is out of phase with the front response, whitch is part of the trick, i know. But it disturbs me... (personal preference).
Before 3 or so Sat works for me.
Ok, will probably be 11:-12:00 noon-ish.
jeff
Jeff has made it and the FHXL w CHN-110 are playing Sexy Sadie right now.
These started with no break-in at all, we are maybe 15 min into them.
They are really quite good even with no time on them. Detailed, full throated. Bass is decidely there, but seems constrained (most likely due to no break-in, but possibily exacerbated by the FHXL being on the smallish side for these (better in Joan by the sims).
Pictures to come.
dave
Pictures to come.
dave
OK, some more noodling.
These drivers are $113 from Madisound, add a Joan flat-pak from Bob (or diy from scratch), an inexpensive 50ish w Class AB or Class D, and a source, one could have a really decent system for under a grand. And it will play fairly loud enuff rock-n-roll for most people, have sufficient bass to satisfy, sounds good on both female & make vocal, shows very good detail on plucked guitar (a somewhat similar EnABLed driver does better).
I also have sims suggesting 10-35 litre reflex if you can live with less bass (the big box looks to go near as low, but won’t have the LF gain.
dave
dave
Did you play around with your stable of amps, or just the First Watt? Some folks would be interested in impressions with combinations of stereo or mono’d ACA.
Yes, a bit of a surprise these drivers are, especially with what we're used to in terms of "break-in" time from other Mark Audio drivers. The 110 is quite nice in the FHXL, and may satisfy some builders in terms of bass depth, which isn't too shabby "as is". A little woolly, but we're assuming this is due to being a brand new driver. Mids and treble are very smooth. Could be very impressive in a Joan.
You're going to want some power behind these drivers if you like your music to have a bit of slam. They play very nicely with Dave's Sit-3, but the amp was audibly clipping on one track.
jeff
jeff
- Full Range
- The new Mark Audio CHN-110 6" driver
