No-global-loop amplification
Here are the build guides for them. BOMs and schematics are in the guides. For Simpelstark Amps change R16 and R18 to 220R resistors and connect the bias inputs to a single emitter resistor on each amp board.
Trying to find the best way to mount transistors.
Is it better to use an aluminium flat strip for transistor mount than screw each one separately?
This causes as many arguments as picking a wire type! The best way to mount transistors is to clamp two with a single screw in a U shaped channel to proper torque specs. Everyone over tightens them though and destroys the u channel causing uneven clamping force. The next best option is individual screws in each transistor. A bar across more than two transistors is a bad choice because any variation in the thickness of the transistors, ect will cause uneven clamping pressure.
Can all these Q7,8,11,12 share the same heatshink?
If so i will use this configuration.
If I didn't design and sell my amps, I would use Valery's. I completely agree with his design philosophy and would love to see more subjectives from builders.........
Hugh
Yes even I admit that. He is one fantastic person who lives life at his best by both audio and sky diving. His thought process is amazing so as his kindness as well and never ending thirst for great sound.
