The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
I have just seen you own LP12/EKOS/KANDID, the best choice!
Is this Klaus' audio system?
I was in Koeln in 2019 May and I met Klaus and Hans to listen to Klaus' system.
Yes it is, he and Moni are good friends of us. His system is really impressive. He also uses the DDDAC
here is a nice report from one of my visits with Dick from Audio Creative link here ...
After a little tweaking these are the phase noise plots of the Differential oscillator TWTMC-EXO at all frequencies (except for the 12.288 MHz, crystal not yet available).
And the phase noise plots of the New Driscoll oscillators TWTMC-DRIXO.
Same crystals, same performance, same cost, same size, the only difference is the little higher output level of the DRIXO.
IMHO, it would be wise to present your stuff in a web side, so turtles may understand your product palette with figures, sizes, output shape, performance and comments about as they come on the table.
>> As I missed within the XXX pages
TWTMC-EXO Differential oscillator: is this a symmetric sine output or??
While you have the expensive measurement gear to complete as a product and easier order tables..
just my 2 cents
Hp
I did listen to his system, the dynamic was really impressive.
He also use my old Driscoll design (TWTMC-D) at 22/24 MHz.
I have built a pair of these oscillators for Klaus and Hans a few years ago.
What a small world we live in. I have also visited Claus his system some years ago. Claus is a nice guy and his horns are very impressive, as is his listening room.
Hello Andrea, Hope you're doing well.
These results are truly remarkable, specially the 11.2896 MHz oscillator. I haven't seen anything quite like it.
BTW: What do you mean by "a little tweaking"?
Best regards:
Alex
just my 2 cents
Hp
Let us finish the tests and then I will publish all the infos including some comparative tables.
Best regards:
Alex
Hi Alex,
I meant fine tuning of the drive level of each crystal (single frequency) and a little update of the LC tank used in the Differential oscillator.
The Differential oscillator is single ended output like the Driscoll, I named it differential because it uses the active device in differential configuration with the crystal in the feedback loop.
