Hi Jacek,
I'd like to but modifying the UI is far more complex that the modifications above.
The critical mass is only you at the moment
Just kidding but to be honest I am thinking about a new UI for my DAC and it will require a complete new approach.
This new method will use a totally different GFX library allowing me to do much more and more beautiful things.
Again the DAC will be the pilot run for this and if successful then I could do something for the preamp. The existing hardware on the preamp seems compatible and will need only the addition of a flash to store the GFX elements.
Let me finish the DAC and hopefully a nice GFX solution will come out that could become an upgrade for the preamp for those who want.
Found very good the U8G2 library.
easily portable to almost any display controller / mcu.
I am using it with profit both at work and for personal use.
maybe give it a try
( GitHub - olikraus/u8g2: U8glib library for monochrome displays, version 2 )
You have a PM.i don't really want to sell them, but if i can share the cost that will be great, actually if i order 5 boards to JLCPCB with 4 Layers(PCB Thickness 1.6, Copper Weight 2oz, with shipping and taxes) that will cost around 40$ each, if i order 10 boards 28$ each.
I have to add the shipping for each board to dispatch at each one (320g)
I am moving on the software updates, just finished the new trigger mode last night.
One question to all of you, does anyone plan to use the VFD display?
It is supported but I am quite sure that the UI is still buggy on the VFD as I did not have time to put a VFD panel on my board to validate everything and nobody used the VFD in the past build on HCFR as display area is limited.
But it is supported indeed so please let me know if anyone want to use this panel.
Hi Alex,
Thank you for the update on the software.
Unfortunately, I'm currently using the VFD display with my build. I looked into using the dual OLED display but the chassis I'm using is from one of the group buys on HCFR and the cutout for the display is too small for both OLEDs: 151 x 29 mm (it's by far my favourite chassis; the craftsmanship is unmatched).
The only small bugs I've come across were when changing input or output names: some characters would appear when moving to a blank space, but that's easily fixed by changing them back to a blank space and then saving the name.
@ schultzsch you can order directly from Noritake in Germany.
GU-7000 Series: SHOW AND TELL? Modules
The final version is 288mmX288mm and i will order soon 10 boards around 34$ each.You have a PM.
I had PMs from some off you who are interested. Please confirm.Thanks
sorry I lost the track, what is this new psu exactly for?
- UGS-muse preamp GB
