Hello, I'm looking for the best 2n3055 amplifier project. I have a lot of this transistors so i want to use them. The project should be modern and the amp should have good parameters. Thanks!
Pay a visit to this thread. Lots of choices.
2N3055 inside - commercial famous amplifier models, quasi complementary power output
George
George
1.2n3055 are different.
2. There are different schemes.
3. What do you expect from a DC servo drive?
1. I know
2. I have only NPN, so quasi complementary
3. To minimize DC offset at the output
Radio Fernsehen Elektronik, 1977, No14, S. 459-462, 467
Стр. 61 журнала <<Радио>> № 4 за 1978 год
Class B w/o crossover distortion (1975)
That one doesn’t exactly “minimize DC offset at the output”. You would need a separate bootstrap capacitor to keep the VAS current out of the speaker. Easy mod if you wanted to do that.
Cap coupled speaker is probably a good idea when using 3055’s of unknown origin above their 60V rating. If they blow you just lose a couple of expendable 3055’s (and a Cheap BD139/140 pair) and not the speaker. A DC servo won’t be able to correct that situation.
I have stronger version of 3055 - KD503 made by Czechoslovakian Tesla
Classic.
Author of the scheme V. Lamm/ Vladimir Shushurin
This is an amp that I actually designed with Toshiba Power Transistors, but the circuit works also good with 2N3055.
Thanks for all your propositions, what do you think about QUAD 405 with KD503 output transistors?
How thermal tracking is done? Which transistor is doing it?This is an amp that I actually designed with Toshiba Power Transistors, but the circuit works also good with 2N3055.
I built a Quad 606 clone with MJ15003 transistors, I had problems with stability. It might work better with the 2N3055.
I have build a similar circuit with 2SC5200 and 2SA1943. In class AB/C it worked already, but in class AB it begins to oscillate.How thermal tracking is done? Which transistor is doing it?
In class AB/C, thermal tracking also worked fine. The power transistors are switching on when the driver transistors go over 24mA.
If you look at a 20kHz signal, you can see small transfer distortions, but these are in the range of a few hundred kHz with a tiny amplitude. Not even bats can hear that😉
This would actually be a case for current dump, but my previous experience with current dump has been rather disappointing.
I suggest the best 3055 amp would be a Blameless-type architecture but with a quasi-complementary output stage if that's what you require.
I presume your 2N3055's are modern epi devices, not RCA original (slow) ones.
Crossover distortion can be reduced if the frequency compensation is made with a local inclusive compensation which can also be given a transitional compensation, but the circuit needs a couple of minor adjustments - mainly an increased input stage degeneration and an increased VAS degeneration from Self's original.
Thanks! I'll take a look. Have you seen 2n3055 amplifiers with DC servo?
Servo has no connection to type of transistors used..
Btw I remember making my first amp with those old TESLA KD bjts, in late 80's 🙂 I could only find the datasheet with numbers, hfe>40 and ft 2Mhz.
- Best 2n3055 amplifier
