Once all dependencies are there the gui part is quite easy. You just have to download and install the pycamilladsp and pycamilladsp-plot libraries, then download the backend and start it. I started making a script to automatize the installation on a Raspberry, I could do something for mac as well.Is it possible to include the gui into the macos build? I'm not lazy and probably don't really know what I'm asking for but this would of course make life easier for us software half-illiterates... 🙂
The libraries pycamilladsp and pycamilladsp-plot you can put anywhere since the downloaded files aren't needed any more after installing them. You can delete them when you are done if you want.OK thanks - can you please give same advice on folder structure - where to place things and how to structure it in a good way?
You just need to keep two things: the camilladsp binary, and the folder with the backend. I would suggest to make a "camilladsp" dir in your home folder, inside that one make a "bin" dir where you place the binary, a "configs" dir for storing your configs and coefficents and a "gui" folder where you unpack the camilladsp.backend.zip.
(base) MBPr-2:Camilla MBPr$ ls
camilladsp camilladsp-macos-amd64.tar.gz
(base) MBPr-2:Camilla MBPr$ camilladsp
-bash: camilladsp: command not found
?? (ignorant..!) :-D
Thanks!!
The unix terminal has one quite annoying "feature".. The current directory is not considered when you type a command, like "camilladsp" in this case. It will only look in the folders in a defined list (usually kept in the environment variable PATH), like /usr/bin etc.(base) MBPr-2:Camilla MBPr$ ls
To make it run a binary or script that is in your current folder, you have to add "./" in front. Try: "./camilladsp -w -p 1234" or just "./camilladsp --help".
Thinking a bit about this as I was searching in the thread for how to list for Camilla available ports and streams...
One should resort to the very last step to do attenuation so to let all EQ/phase computation have the most available no-of-bits at hand to do it's magic on. Then introduce, as last action, inter-over avoiding defence (-3,1 dB I believe it is).
When it comes to attenuation, there could be other reason in a specific sustem to add none-destructive attenuation. This can be made by shifting out the LSB (sucking in a 0 in MSB), corresponding to -6 dB. This together with dither should be the best way to attenuate a PCM stream. So a feature request: Att_shift=1,2,3...15) to do -6, -12, -18 ... -90 dB attenuation with no bit effect than losing the 16th (24th) bit into devNull.
So a Att_shift:1 + dither on the 15th bit, positioned in the end of the processing pipe, should be SOTA attenuation!?
PS: terminal command to list streams? 🙂
I can't understand that you could have a life without 😕....😀
I created an test.txt in REW (Generec EQ). The "filter" is BiQuad as can be seen in the attached file for LEFT channel...
My flow should be like this in the camilladsp pipeline...
1) PreEQ as BiQuad (flat target proberly)
2) FIR filter
3) Some -2dB gain to avoid clipping
My workflow should be as this for creating the final result :
1) Measure at sweetspot (excatly in the middle).
2) Create flat target BiQuad with thoose measurements
3) Apply the BiQuads to Camilladsp, and start camilladsp.
3a) Maybee apply -2dB gain now???
4) Measure again same spot with BiQuads in place
5) Create FIR's with thoose measurements
6) Apply the FIR's in camilladsp pipeline
Done!
Jesper.
All internal calculations are done with 64-bit floats: Double-precision floating-point format - WikipediaThinking a bit about this as I was searching in the thread for how to list for Camilla available ports and streams...
This means that dividing by 2, 4, 8 etc doesn't lose any bits, just the exponent changes. It doesn't matter where in the chain you put attenuation, the final result will be the same in any case.
I have planned to add a linear gain option, where you just specify a multiplication factor like 0.5 instead of a gain in dB. For now, if you want a factor 0.5, put -6.020599913279624 dB which is so close that the difference will be lost in the rounding.
Then again, if you are actually going to do any filtering, then the whole bit-perfect idea just vanishes.
I forgot about the terminal app to list streams, sorry!
You can use the "enumerate" example from CPAL: GitHub - RustAudio/cpal: Cross-platform audio I/O library in pure Rust
It's easy to compile, but you need rustc and Cargo installed. You run it simply with "cargo run --example enumerate"
My stream-listing-app will be just a slightly modified version of that example.
OK. But every little thing helps... (?) 🙂
Cant compile.. (compute 🙂 )
Yes, filtering of course ruins everything 🙂
So you will have an app?
Yes I will make a simple command-line utility to list streams. The app itself is very simple to make but I'll need some time to set up the automatic building. Not much use if I don't publish ready-to-use binaries 🙂
Done!Great - I'll hang around for that one 😉
Release First release * HEnquist/cpal-listdevices * GitHub
This is a simple command line tool for Windows and macOS that just lists the available devices and their possible values for sample rate and sample format. There are pre-built binaries available, see the link.
U - wizard! 🙂
(base) MBPr-2:bin MBPr$ ./listdevices
Available hosts:
[CoreAudio]
CoreAudio
Default Input Device:
Ok("Built-in Microphone")
Default Output Device:
Ok("Digiface USB (24007543)")
Devices:
Device: "Built-in Microphone"
Capture
Default input stream config:
channels: 2, samplerate: 44100, format: FLOAT32LE
All supported input stream configs:
channels: 2, samplerate min: 32000 max: 32000, format: FLOAT32LE
channels: 2, samplerate min: 44100 max: 44100, format: FLOAT32LE
channels: 2, samplerate min: 48000 max: 48000, format: FLOAT32LE
channels: 2, samplerate min: 88200 max: 88200, format: FLOAT32LE
channels: 2, samplerate min: 96000 max: 96000, format: FLOAT32LE
Playback
Device: "Built-in Output"
Capture
Playback
Error: BackendSpecific { err: BackendSpecificError { description: "AudioUnit(InvalidPropertyValue)" } }
Device: "Digiface USB (24007543)"
Capture
channels: 8, samplerate: 44100, format: FLOAT32LE
channels: 32, samplerate min: 32000 max: 32000, format: FLOAT32LE
channels: 32, samplerate min: 44100 max: 44100, format: FLOAT32LE
channels: 32, samplerate min: 48000 max: 48000, format: FLOAT32LE
channels: 32, samplerate min: 64000 max: 64000, format: FLOAT32LE
channels: 32, samplerate min: 88200 max: 88200, format: FLOAT32LE
channels: 32, samplerate min: 96000 max: 96000, format: FLOAT32LE
channels: 32, samplerate min: 128000 max: 128000, format: FLOAT32LE
channels: 32, samplerate min: 176400 max: 176400, format: FLOAT32LE
channels: 32, samplerate min: 192000 max: 192000, format: FLOAT32LE
Playback
Default output stream config:
All supported output stream configs:
channels: 34, samplerate min: 32000 max: 32000, format: FLOAT32LE
channels: 34, samplerate min: 44100 max: 44100, format: FLOAT32LE
channels: 34, samplerate min: 48000 max: 48000, format: FLOAT32LE
channels: 34, samplerate min: 64000 max: 64000, format: FLOAT32LE
channels: 34, samplerate min: 88200 max: 88200, format: FLOAT32LE
channels: 34, samplerate min: 96000 max: 96000, format: FLOAT32LE
channels: 34, samplerate min: 128000 max: 128000, format: FLOAT32LE
channels: 34, samplerate min: 176400 max: 176400, format: FLOAT32LE
channels: 34, samplerate min: 192000 max: 192000, format: FLOAT32LE
Available hosts:
[CoreAudio]
CoreAudio
Devices:
Capture
Playback
Capture
Playback
Capture
Playback
... but don't they have identifiers/names so that I can adress them in Camilla?
Yes, you should put "Digiface USB (24007543)" as device!
Stream seem to correspond to approx "Cable" and Channel is like Left etc..
Could you please post an example of a basic Mac configuration that I can work from..?
All devices I have present just a single stream, like this one (in Audio MIDI setup):
Could you post the same picture for the Digiface?
This is a config I have been running:
Code:
devices:
samplerate: 44100
chunksize: 4096
target_level: 2048
adjust_period: 10
enable_rate_adjust: true
resampler_type: BalancedAsync
enable_resampling: true
capture:
type: CoreAudio
channels: 2
device: "Soundflower (2ch)"
format: FLOAT32LE
playback:
type: CoreAudio
channels: 2
device: "Built-in Output"
format: FLOAT32LE
filters:
lowpass:
type: Biquad
parameters:
type: Lowpass
freq: 20000
q: 0.5
pipeline:
- type: Filter
channel: 0
names:
- lowpass
- type: Filter
channel: 1
names:
- lowpass
Hi!
The whole list don't fit but you get the hang of it...
Wonder what corresponds to channel in:
pipeline:
- type: Filter
channel: 0
names:
- lowpass
"ADAT 1-8 ADAT 1" ?
This is why I asked for your program to list the channels so that one could get a view of how the system sees them...
pipeline:
- type: Filter
channel: 0
names:
- lowpass
"ADAT 1-8 ADAT 1" ?
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
