F3 Builders Thread
Your 10% error in resistance will give you 10% error in current.
For resistors in the one digit Ohm range, I use a constant current source of 1A and measure the voltage drop over the resistor. That gives me a more precise value.
Do you have a bench supply with current limiting function?
I can adjust Vd such that Vgs=1V. But I am sure that Vd will be lower than 3V. I forgot the value, maybe 2.x. I don't remember
Today I bought two LUs from Jim's Audio. I redo the test and found that the Vgs only got 5xx mV, so pretty sure that they are counterfeits.
Everyone, please tell me where can I get the genuine LU1014D? I have been spending few months on building the F3 and now I cannot continue my work due to missing of the most important parts. I am very frustrated, can anyone help?
Found these on eBay in Hong Kong:
6pcs LU1014D N-channel power J-FET 2 pieces for SE amps and Pass F3 | eBay
They look like the real deal.
I have some real ones I don't need also, but shipping will be cheaper to you from Hong Kong.
Rush
Hi edwtsui,
I have quite a few of these you can have if you want - these were the last of Grey Rollins' GB some years ago and closely matched for F3 current use. I also have a couple of spare partially assembled boards too if they would be of any use to you.
Rush
I bought some of these. The items don't match the image.
The right one is a genuine part, the ones of the left are what arrived. The legs are really flimsy too - snapped off while bending them to measure.
For me personally, I will avoid where ever possible purchasing electronic components from certain countries that are notorious for producing counterfeit parts.
I'm not sure where to go with this.
I do the same because it's such a huge time/aggro saver. But that's profiling, and I'm sure a cop in the 1980's would have said the same about stopping black drivers....
So what does one do?
