JFET input phono preamp for MM
It is again about overall design. However, if under same conditions FETs are 3 orders of magnitude less sensitive to RFI than BJTs, I have no reason to prefer BJTs especially on the position like the input of the phono preamp. BJTs have no single advantage here.
dreamth, you are not bringing a single engineering point, so I am not taking your posts into account.
JFET’s are better for RFI, but my point is you can take measures to ameliorate the problem with bipolars - no need to write them off.
I don't think Pavel writes BJT's of. He just gave his rationale why he has chosen JFET's and not BJT's.
For MM input the choice of JFET's is quite straightforward, not that much reasons to use BJT's and trying to ameliorate the issues coming with them for this kind of application.
The square - law induced distortion of FET's cancel out nicely due to the complementary and balanced input.
I rely on true engineers that already knoked you down several times, but fact is that you refuse to accept that and rely on attacking weaker's chain links .That won't make yourself any favor...You need to beat the head of the pack if you want to be recognised the alpha male, and i'm not that one !
I have Picked up am radio stations on fet input phono in fairly remote areas so it can still happen. It was also atmospheric bounce and not even local so rather low frequency. NYC can be especially bad if across from the antenna in a penthouse.
Ferrite beads fixed it up.
Now that I know they sound bad I better remove them from all our Stereophile class a rated products.😀
let's just give PMA a break by rebuilding his self esteem with a real world circuit versus the " standard marantz engineered design" .Marantz PM62 schematic has some input ferrite beads too, but the circuit is actually a clone of technics Technics SU-V6 which is using no ferrite bead .Marantz is not using them either in the real circuit depending on the country version because some countries are more strict on emi than others...my uk version of PM62 was using some shunts instead of the coils, but that doesn't mean anything as 2sk369 has already 75pf input capacitance by itself and aditional capacitance at the input is added physically too and some shielding ...
It's the best way!
I still remember you claim that a digital phono eq was showed and demonstrated at AES which, after being a true inquisitor to find the true source of your information, i found that it was actually not a real piece of hardware, but a cartridge connected to an adc and connected again to a real computer running advanced algorithms to do it...Well..i couldn't source this information from AES site either... many of your claims are biased and true blunt lies too so you know my opinion on you too 🙂
And i forgot to mention that, the Marantz pm 62, even after being modified back to standard Technics version couldn't deal with dust at 33rpm in no way with shure v15 type 3 and D75(yes..i used them both on Dual CS-701 and Sanyo Plus Q-50 ...hopefully low noise enough turntables for your audiophile taste )Supplied at +-18v, Marantz behavior on dusty records compared to my aiwa bipolar preamp supplied at only +-15v is not even worh mentioning its quality . I simply stripped the circuit taking all the components for other projects cause my "technician" background couldn't cope with it... A phono preamp needs a lot more attention than just for SNR to be a good one.Ask J L Hood if you can't believe me.. unless his liniac SNR give you some weird allergies.
I have seen a couple of people mention that LM4562 can pick up DECT phone transmissions very easily but not worked out if this is due to input technology, or something internal.
Hi Bill,
Never too old to learn, this was something that I never came across before, but there seems to be a real advantage for the Fet.
So the Opa1642 that I favoured is at least not a bad choice at all.
Anyhow, the LM4562 has too much current noise for a low noise MM preamp, so this is not the preferred opamp for the purpose.
I wonder how and if this Fet advantage for MM also applied for an MC preamp, or are they only advantageous for high impedance applications ?
Hans
[...]I wonder how and if this Fet advantage for MM also applied for an MC preamp, or are they only advantageous for high impedance applications ?
I would think that for MC the current noise issue is simply not relevant, and therefore you can use BJT input with high collector currents, making the whole issue less important.
However, paralleled low noise JFets work great too in MC pre's, albeit not if you're after the world record in low noise.
There’s some LM4562 stuff out there. It seems there is a general problem with noise - see the comments section on the TI website For example.
I’ve personally never had a problem of any description with the 4562 in line level applications but I ALWAYS include some sort of LP filtering on my designs whatever the amplifying device. On Phono, an LM4562 does not cut it noise wise. Better to stick with a 5534A.
ztx1051, ztx1055 and ztx1151 are better with higher hfe, but these are very high currents switching transistors and i'm not sure that their hfe is high enough at usual mc cartridge currents.
