What are critical connections if wiring this point to point? Or you think it should not be done at all, cause more noise?
It might be months before the PCB group buy goes through.
Can't answer that question. It takes making and measuring a specific point to point build map against the regular. I don't say it can't work decently if you try one.
Do you know what filtering is on the mains of the ATX PSU?
Can I keep this filtering? Already has AC socket and switch.
Less wear on my arthritis hands.
I would just wire up the ends to the trafo.
Good idea to use the old Psu case as a new case for the LAdapter!
Does anyone know a online retailer that sells aluminum cases I can use in Ladapter ? That ships worldwide? I saw in ebay but they are kind o expensive!
They don’t need to be fancy.
Only Ebay that I know of. Prices for the Chinese cases have gone up, including shipping prices.
Depends on your trafo size, you could stack two smaller cases?
The smaller chassis are usually free ship on Ebay.
ThanksOnly Ebay that I know of. Prices for the Chinese cases have gone up, including shipping prices.
Amazon ships to Brazil?
YaeCCC Aluminum Enclosure Metal Shell Electronic Project DIY Box Case for PCB Instrument Amplifier - 255 x 205 x 60mm / 10"x 8"x 2.36"(LxWxH) - - Amazon.com
If I add a 5VDC 40mm Fan for the rpi4, does that defeat the clean power of the L Adaptor?
Don't power anything else from the PSU's output than the Rpi itself. Electric motors are especially noisy.
And the generator is ok?
A friend was recently looking for a portable 2ch oscilloscope + gen tool and ordered this:
Hantek 3 in 1
Yes , they do. I will see. Thanks
Hantek 3 in 1
Thank you. Does it also generate the appropriate signal?
"Amplitude: 2.5Vpp(50Ω): 5Vpp(High impedance)" so its enough. It also keeps the gen running after switching to scope.
Very good. I will buy it. Thanks
2D42 or 2D72. 2C models don't have a generator shows the table in the brochure you posted. I couldn't find anything better value for your purposes, I hope you will find it useful. Gives you a fully developed digital multimeter mode as well.
- Power Supplies
- L-Adapter
