DAC AD1862: Almost THT, I2S input, NOS, R-2R
The Digital input selector based on the AK4118 chip arrived. It has SPDIF x4 + USB x1 inputs to I2S output with a screen that shows locked status and sampling rate. Works very nice! No pops/clicks when switching inputs either 🙂
How did You get it?!
By luck in fact.
Don't look any opa860 in the link nore Thorsten Losch? while there was the 660 already used. My memory tells me it was : AD844, then opa660 (no feedback) then its sucessor opa860. There was in between an ADA something too (or at buffer after the 660 in the old Ayas ?
Edit : oh I see : last post of the link 😉 , think the design is older from the AD844 when these cool people was talking together in an other forum ?
I got this set-up fired up at 2AM 😱
I only switched between optical and USB and listened for a short time to confirm all worked as it should. I’m also curious if there is any sound degradation between SPDIF signal and USB to I2S.
Caro Diggy.. 🙂
The shown circuit is only that far actual, that Vunce could literally take it as it is, and apply to his 860 circuit. The two are pin compatible, function compatible, 860 is the legacy product after the defunct OPa660..
Take note of the discussed base damping resistors, (pin3, pin5..) etc..
Ciao, George
Caro Diggy.. 🙂
Ciao, George
yup,
think it will benefice of more filtering on the voltage prg chip with 1 to 2 uF film // to more than 470 uF. and a Tip 142 emitter follower something... where did I see that 😉
The trafo also needs an I/V resistor, either in parallel with the primary or secondary of the trafo.
Not sure of the advantages of having it on primary or secondary, I think if the primary winding resistance is too high the IV resistor must be on the primary.
My trafo does not have centre tap on the secondary and it can still drive a balanced input, not sure if thats possible with all trafos though.
The trafo is an awfully expensive option and probably wont outperform either a passive IV resistor without a trafo or op amp IV, simply has its own set of compromises.
The trafo is probably the most ''natural'' sounding but the least transparent option to my ears.
Actually ''least transparent'' is not really accurate, least consistently transparent would be more correct, it depends a lot on the music how well it performs.
