DAC AD1862: Almost THT, I2S input, NOS, R-2R
yes but the point is regarding passive IV increasing the sensitivity to supply quality compared to active IV, whether this is a trait of passive IV with CC dacs or any current output DAC.
I don't thing it has something to do with a passive I/V, because active I/V can provide much lower impedance (and load) than a passive resistor (unless 10R or so was used).
Joined 2014
Unfortunately, I do not have good news to report :(
I’m getting background hiss from the speakers that can be heard from 4 feet away, no hum. Possible oscillation? DC offset is very high 100-120mV. With music playing there is audible distortion. When R4 was increased to 2K4, there was no increase in volume output.
I checked and double checked for errors with my implementation of the OPA860 circuit, it’s good, No shorts or solder bridges.
I will try a different location for R4 &C1 GND point. Currently they are tied into the vacant C37/C38 ground pads.
Joined 2014
I Reinstalled the first dac board that is unmodified and have the BursonV6 opamps installed. My spirits have been lifted again!! The combo sounds fantastic :D
I haven’t given up yet though, I will try to bypass the onboard OPA860 buffer, essentially making it an OPA861. (Those are also on the way ;))
Disabled Account
Joined 2019
Hm.. I can confirm that OPA861 (both..) in the circuit of Pedja (as told, I am having the Aya dac) is perfectly functional, zero instability. And sounds very good..
Yup ! Despite no decoupling at its feets, the magic of a good power supply design -the 100 uF caps are strategical there I mix both 47 uF & 100 uF, so a litlled isymetry, lol- Nore I use the 1500 uF Pan FM btw.
Disabled Account
Joined 2019
Then, try to place a small smd ~10nF (or 100nF or between) directly on top of the smd chip, between - Vee and +Vcc (+_5Vpins, pin7, pin4).
All these things are needed, in reality, to maintain good stability..
Ciao, G
Sure, as I questionned : those chips lives bad to be on a socket, on adaptaor, should be directly soldererd and careffully decoupled right at their power leads.
750 ohms is ok after the opa861, it's what I use on the AYA before the buffer..., still the opa861 reversed in mine but a better buffer should exist... though the opa861 reversed is neutral fr my tastes. Ok off topic, perhaps can give some thoughts for Vunce.
Edit : are the pins of the opa861 copatible with most opa in a swap operation ??? Not sure it is iirc! Vunce, did you populate the miro's pcb or hacked the outputt with a wire on an extra board and managed a ground between the two boards ? Or I'm not understanding you are talking about the verroboard ?
