Lanzar optidrive 2000D
I just changed few outputs which were bad and tried to on the amp and it is pulling about 3.3 amps current on idle. It is getting good sinewave output. Is the current pull is normal? This Caries two transformers with a set of 5x5 mosfets on each transformer.
You can replace Q124/5 now or when they cause the amp to fail again, likely when it's within your warranty period, if you give one. The risk of the drivers causing the amp to fail catastrophically is extremely high and the cost to replace them is absolutely insignificant in comparison.
It could be that the CCS is set a bit too high but I wouldn't adjust it before replacing the drivers.
Q124 and Q125 are big transistors attaching the picture. I am trying to find if I have them in stock.
