Lanzar optidrive 2000D
It is getting hot plenty.
When use small transistor driverboard it did not heat. I took out all transistors from driverboard test them individually and replaced them and it is still pulling current and 1 fet getting very hot. All gets are brand new from digikey.
I'd move the FET that's heating to see if the problem follows the FET or the location.
Even good quality FETs can have different thresholds. Having matched date codes helps but it's no guarantee. Are the date codes matched for the FETs you're using?
Does the amp overheat (compared to the other driver board) at idle?
