Hypex Fusion bug and wishlist
Auto off in the device settings panel?
Here is a screen shot on one of my amps (FA252)
I don't see any option to turn Auto Off, I can select Off after xx min. but even if I select 30 minutes for example, the plates mutes after a few minutes without signal
Hello,
my problem with HFD, after 'enable recording' and 'take measurement' I don't get a sweep.
With FA253 1.42 I had the same problem, til I tried to switch invert to on. Only inverted I got the sweep, don't ask me why.
Now with firmware 1.44, no sweep anymore. When I start measuring, I get the message: 'Argument out of range'. This happened in 1.42 as well, but after starting measurement again, I got the sweep. Not in 1.44
While the measurement runs, the mic records the noise in my room
I'm using a laptop, W10/64 bit
Asio4all got the full control.
Usb soundcard:Behringer UMC 22 and UMC 202 HD
Microphone: EMX 7150
I changed all cables a few times to make shure no cable been broken
I tried for days and days and days all kind of Windows and HFD settings.
If someone got this problem as well or got an idea . . .
I read all Fusion and HFD forum(s?) complete (English,German,Dutch)
someone measured everything inverted like me.
I think I'm going to try Arta even I don't like to transfer data by hand
