OK
To fix Vout can decrease R101-301 resistor to have more CCS?
Yes. Even trimming down by paralleling another higher value one on top.
CCS resistor two paralleled 1.2R, Vout fixed 10.5V, two red Vref LEDs don't lit.
Output load is 5 Ohm?
Very fishy. Remove Q104 and Q103 to check them with DCA. If they are both good (doubtful) then it must be Q105 to had betrayed them.
Oops. So without tester. Do this, after you remove Q104 replace it anyway. And see if Q103 Q105 show any D to S short on Ohmmeter.
Buy a cheap tester from eBay maybe. Does basic parts recognition stuff reliably. You know those naked little boards with screen and long test socket.
- Power Supplies
- SSLV1.1 builds & fairy tales
