F6 Illustrated Build Guide
F6 - dual mono
Kind of a slow day here on the quarantine scene, so thought I would post a picture and thank everyone for the help and inspiration that this site and thread gave me. Especially Nelson for the design and support.
I needed to do a rebuild due to outside issues and thought I might as well try to squeeze more parts into this box, inspired by other's posts here. It's tight, but is working well and is quiet.
Thanks again everyone
Very nice @SR427!
Hello.
I am gathering parts for F6.
This is first time to build firstwatt amp.
I am considering to order r-core power transformer(300VA-400VA) from phenix.
Their transformer have one primary and two secondaries.
So I have a question that I should have one CL-60 or two in parallel
or go for soft starter.
I have all my parts on order to complete the F6.
So excited but shipping delays!! Arghhh
It’s a single PS standard build with 400VA trafo from Primrose Audio.
I’m thinking of going integrated with the B1 Nutube as the pre.
I think this will be a nice combo?
Is there any detriment supplying the B1 from the same power supply as the F6?
I.e from the +ve rail and ground? Should have enough headroom?
Do I need to isolate in any way?
Using DIY audio Universal board with 74000uf per rail.
Cheers
Cheers
To quote Papa from the build guide:
"The preamp can be made to work with other supply voltages, but you will find yourself adjusting resistors and also needing a distortion analyzer to set the Nutubes for the desired distortion character. Easier to use 24V. If you use a linear power supply, you will want to have it regulated, as we need a constant DC value regardless of AC line voltage."
A small hard wired 24V SMPS run off the AC line inside the chassis would be the simplest most reliable way to get the job done, and keep the two circuit supplies separate. About the same price as the original spec external Triad supply:
https://www.mouser.com/ProductDetai...=sGAEpiMZZMsPs3th5F8koBFO1FnQkaDCUHGsdtbrlqs=
A isolated DC-DC converter off the + V should also work but maybe someone could weigh in on possible ways it could affect the F6 sound? Doesn't save any money:
https://www.mouser.com/ProductDetai...GAEpiMZZMvGsmoEFRKS8NQI34ISr4%2B/bVK7nGRtBrg=
From the Korg B1 article:
"Also, the circuit has a turn-on turn-off thump. You can leave it on, and it draws .06 amps at
24V, and it won't impact your electric bill. Alternatively, you can be sure to turn it on first and
turn it off last in the system."
This may an issue if you build the B1 Korg and F6 as an integrated.
Adding a pre to an F6 is IMO a curious desire. Clearly the intent of someone who doesn't own /use one.
Suggest listening to the F6... before... adding to it.
An F6 is 100% Dead silent . Also accepts a Simple Stepped attenuator as a pre ( or if Flush .. a transformer volume control)
beautifully for a Straight wire from the source clarity. Adding a pre is unlikely to improve on that clarity.
Agreed! I use the original B1 with my F6 (not in the same case) and it is a great combo, but would not want to be locked into it. Want freedom to try others. Plus don't want to share the F6 supply with any other gear - I'm power greedy!
