New full diff amp OPA1637
TI continues to surprise us with top notch products. After the OPA1656 I 'discovered' the OPA1637. A fully differential amplifier with excellent audio specs.
Ordered the eval module to get a head start*. I can see several places where this would fit very well, like fully balanced post-DAC filtering and/or I/V conversion, fully balanced preamps, fully balanced active filters/xovers. And, my own target, an improved fully balanced AutoRanger.
Anybody here with similar ideas?
Jan
*If the international shipping system holds up, hopefully.
Reactions: Johno
The datasheet looks good, the inputs seem truly symmetrical. All too often differential amplifiers have very poor AC common mode rejection.
Your post reminds me, I want to build a decent connector board to bypass my PCs horrible 3.5mm jacks
Same pinout as OPA1632, it seems, but a less hot input stage with added input bias current cancellation (no biggie in a true balanced application). This part would be intended for more normal surrounding impedances. You could use it in a fully balanced phono preamp, I guess, but the duplicated RIAA network in these is always a nuisance.
We're not exactly drowning in these fully-differential parts, so any new type is welcome I guess.
BTW, I never noticed that OPA1632 specs do not really add up. 2 µA of input bias current (typ) but only 0.4 pA/√(Hz) of input current noise? You'd get 0.8 from shot noise alone. (Besides, even the lowest-noise bipolar opamps do not manage en * in substantially below 1. OPA1632 specs would indicate 0.6!) OPA1637 specs look way more realistic.
Got some time to check out the OPA1637 EVM. Some EVMs have 0 ohm output isolation resistors in R4, R7 positions. The latest units will have small non-zero resistors there to guarantee stability with cap loads. In case you do see oscillations, check that these resistors are non-zero.
But, with that, the performance is absolutely stellar, see attached. Measured via a balanced twin-tee, down in the AP noise floor ...
And this is with a gain of 5, so for unity gain expect at least 10dB lower yet!
Jan
That THP210 is typically meant for battery/low power systems. The supply current is just 0.95mA, but the trade-offs are also visible: GBW less than 10MHz, slew rate 'just' 15V/uS.
So these are two different products, for different target applications. But it may be a nice candidate for a differential servo ;-) .
Jan
So ?
How does it compare to the OPA1632 ?
Is it meant to replace it or...?
I must confess I'm confused with TI's nomenclature and op-amp marketing... EDIT : even more so when it seems THP210 is the SAME part but with better input offset voltage ? Because it's not a "Burr-Brown Audio" part but sorted in the Precision Op-amps range ?
