Orion XTR PRO 2400
After removing the audio driverboards .
Here is what I get on the 3 pin connector now
So I’m guessing it’s a driver issue
I replaced all of the drivers .
Here is what I get on the 3 pin connector now .
Do these drive waves look correct or do I still have a problem possibly a bad LM361?
Scope settings are 2us 2volts /div
First pic is with the audio driverboards removed and the 2nd pic is with the audio driverboards installed.
Scope settings are 2us 2volts/div in both pics .
Post 45 the top edge of the waveform looked better with no audio boards installed post 47 appears to have a curve not sure if this is normal or not .
