Bigbottle MM/MC Hybrid Valve Phonostage PCB
Here is the page:
Just put the total in the GBP section and it does it all for you View attachment 833553 Screenshot_20200413-172254_PayPal.jpg
Hello Oliver, appreciated you want to help with the SMD and I accept the offer. Can you just tell me what this means for the price to pay? I added a line in your sheet, just waiting for the final proce to transfer the money. Kind regards.
I have connected the L/V side of things and my unloaded heater voltages across pins 4 and 5 are 6.49v. With the valves in place the heaters glow and the voltage drops below 6.3 volts. Using 6DJ8's with Craigs suggested mod.
With the H/V connected I have the following readings all measured to ground :- V1 pin 1 135.2V pin 2/3/7/8 0V pin 6 135.2V
V2 :- pin 1 149.9v pins 2/3/7/8 0v pin 6 150.2v
V3:- pin 1 236.3v pin 2 17.25v pin 3 16.69v pin 6 236.3v pin 7 17.17v pin 8 16.67v. I forgot to say the led's do not light up.
TIA
TIA
What transformer? If the R26-90 you have to put the LV secondaries in parallel but also make sure they are phased properly!
