Hi Marra, here are the correct voltages:
V1 pin 1 and 6, 82-95V, depends on MM/MC mode, Jfet characteristics and LED forward voltage. More importantly the 33K anode load resistor should have 105-110V at the high voltage end.
This is from the MosFet and derived from a voltage divider from full HV supply.
V1 pin 3 and 8, around 2V (1.8-2.2) again depends on Jfet characteristics and LED forward voltage in MM mode.
V2 pin 1 and 6, around 130V, depends on the ECC83.
V2 pin 3 and 8, around 0.9V
V3 pin 1 and 3, this is full HT, 225-235V perfect.
V3 pins 3 and 8, around 135V, depends on ECC83. Make sure the 1N4001 is in the right way around.
Bas and landiepete see craigstones solution in post 318.
How is a post on diode replacement relevant to my question ? Thx Pete
It is not relevant. He made a mistake mentioning you.How is a post on diode replacement relevant to my question ? Thx Pete
Thank you Alan much appreciated. Are these voltages with the valves in place?
Yes, and heaters working.
Bigma80, good idea.
HmmmmMy vote: Either Analog Source or Tubes / Valves
Tubes/Valves sounds more likely
https://www.diyaudio.com/forums/analogue-source/?daysprune=10&daysprune=10
It will get more attention as a phono stage in Analog source...(not that that is a goal in itself but....)
Oh ok..https://www.diyaudio.com/forums/analogue-source/?daysprune=10&daysprune=10
You win lol
Apologies Pete my mistake.
Thank you Alan.
Craig it's LV secondaries in series, to make 9-0-9, or put another way 18V centre tapped.
Don't worry if it's a brain fart, I've had a big one of those recently 🙄
The R26-90 does not have center-tapped LV secondaries. They are also only 1A rated each so they need to be put in parallel.
Marra - what is the amperage rating of the 9.5V secondary?
Hi Oliver and Craigtone,
Just to confirm about the transformer specification. A secondary of 165 V @ 100 mA and an 18 V @ 2 A secondary with centre tap is the ideal trafo for this build? Or is it better to have a single 9 V @ 2 A secondary with the diode mod as in post #269? I want to place an order for the toroid tomorrow and just want to make sure of what spec to use.
Many thanks for everything so far, Kevin
P.S. Was just checking my valves, and discovered that I have Teonex, CVC & Elites ECC88s and Elites 12AX7s. Also have 2 Elites 6DJ8s.
Fantastic news....inward getting concernedArrived, and lovely it is too.
These PCBs are taking a long time to reach folks
I always get 9.5-0-9.5v @1AHi Oliver and Craigtone,
- Group Buys
- Bigbottle MM/MC Hybrid Valve Phonostage PCB
