germanium Preamp?
Yes , a germanium preamp the noise level is greater than that of silicon devices . Germanium but the sound is very musical ... Yes, and the noise level is still much lower than noise LP records .....The basis was applied to a circuit Telefunken . Was added a buffer stage and applied stabilized power supply ( assembled with germanium transistors )...............I made a few Phono preamp with transistors J-FET . They had a small noise and good sound . But still the sound of a germanium preamp more emotionally...
You would not believe i still have in my possession an old Sparta studio broadcast phono preamp. All germanium. With trafo on output. I recapped the thing, an it works fine, sounds great. Very musical. I do have many much better phono preamps, but this one is a keeper. Now more than half the century old, likely...
Interesting, this thread. Some people prefer silicon, some germanium transistors. As a kid I experimented with battery powered amplifier circuits using both germanium and silicon transistors. I still remember how the germaniums had that nice sound and the silicons sounded lifeless. I decided recently to resurrect a circuit in which I could change the transistor type and the gain and frequency response would be much the same. All that would change would be the harmonic distortion. It was a simple class A headphone amp using a silicon BD140 output transistor. The input gain transistor was the one I could change. The modern small silicon transistors such as 2sc2240 and bc549/bc849 sound very accurate and clear. The germaniums I tried all sound different to each other yet seem to have a family sound. Generally warmer, more depth, noisier and less perfect. As the weeks progressed I preferred the germaniums and the silicons were left in the drawer. I love that smooth, lively sound they seem to make their own. More entertaining to listen to.
I found this one in a thrift store for $3.00
It uses a mechanical power indicator. 9V Battery life is claimed to be couple of months with 4 hours a day use.
PDF Manual has schematic.
  • STP2.pdf
    STP2.pdf
Monacor/Monarch SA-616
... as example.-)
Four-stage-line-power-amp (se-se-se-trafo-pp). But use good speakers and sources,-! You must be very experienced with! Not a horrible big multiway, produced by idiots, used by unskilleds-! Not any big CD/SACD-reference-player, produced by idiots, used by unskilleds!
Tune a little bit (remove the first and the second stage, new-solder, remove some switches ... as example) and start to dream. Very fine, very open, very cultured! Nearly a very very very good se!
... you will remove your XXX-amps,-! No doubt,-!
The hfe of the various germaniums I used were between 50 and 100 at 1ma. I also tried silicon transistors mpsa06 and mpsa42 in the same position in my headphone amp and they sounded boring! The germaniums with similar hfe were full of life and character. I'll need to get out the distortion analyzer and see what's going on.
As far as low gm tubes is concerned, I've always preferred the high gm ones like 417 and good ecc88s. They have more drive, lower distortion and lower noise.
Wow I remember fiddling with circuits like this in the 90s except I used 6sn7s and BD140s. I remember that the tube needs about 30v across it to obtain reasonable linearity.
Just looked up the specs for an MP26A. It can handle about 70v, with a 200mW maximum power dissipation. I guess at those higher voltages the c-b leakage would be high and influential though.
its quite impressive on the analyzer.
i uploaded the plots another thread using fet , if get time will do the mp26 plots here too.
magically the topology does not seem to care about leakage or device varations.
i have not used with a worn out 12au7 yet.
I recently made a new phono preamp using germanium transistors . It contains transistors AC-122 ( Telefunken ) and GT308 , MP-37 (USSR ) . The preamp has a rumble filter .Powered by 24 volt batteries ...
medium
I recently made a new phonopreamp using germanium transistors . It contains transistors AC-122 ( Telefunken ) and GT308 , MP-37 (USSR ) . The preamp has a rumble filter .Powered by 24 volt batteries ...
I love it !
A nice clean aesthetic, something a bit special in this day and age. Looks like a really nice project.
The first 3 transistors (this is a Phono-preamp ) are used АС-122 . The rumble filter is assembled on GT-308 & MP-37. Noise measurement gave a result of - 75 dB with an output signal of 2 volts from peak to peak ( RMAA) ....Now I'm installing the board in the aluminium case . When everything is done , I will show you the result and the scheme .
