Perhaps after rotating the driver 180º, you tilt back the enclosure about 30º (to contain the goop within the surround) and use a hair dryer to assist the migration. It may have off-gassed too much for that to work but it's worth a try. I have seen what happens when solvents get involved in inexperienced hands. Not going to say the drivers were ruined but he never took the grills off again.
don't know myself, but someone will want the specs:
http://www.lansingheritage.org/images/altec/specs/components/421-8lf/page1.jpg
http://www.lansingheritage.org/images/altec/specs/components/421-8lf/page2.jpg
hello,
I have two 421-8LF. Which voice of theater is suitable ? I seem to remember it was combined with mantaray horn.
thanks
Since these are musical instrument woofers with virtually no power handling [~1.27 mm], not the best choice for HIFI/HT apps, but these were the most common combinations [1233 - 1236]: http://www.lansingheritage.org/images/altec/catalogs/1978-mi/page04.jpg
http://www.lansingheritage.org/images/altec/catalogs/1978-mi/page05.jpg
Don't recall the Mantaray as an option with the 421 series, only seen them paired to the 300 & 800 series woofers, but you can use whatever horn/driver/XO combo you prefer and tweak to 'taste' in room.
GM
thanks for informations. 1236 seem to be attractive : where to find plans for cabinet.the most common combinations (1233 - 1236)
GM
The Stanley Screamers had a 421-8LF and Mantaray horn.
The 1236 uses the 828 cabinet, same as the A7.
altec a7 speaker plans - Google Search
No plans found in Lansing Heritage Library.
Any idea where I can get 1236 drawing ?
The closest your going to get with the plans is the 828. I haven't seen a 828C plan that the specs call out that GM posted. It may be just be a minor difference.
Not a lot to see that you can't decipher from the drawings. Many like to foam fill the cavity between the horn flare and the side wall but aside from that, the only thing I suggest is to narrow the port gap to about 50% of what they show unless you plan to use these outdoors or in a very large room.
"fiberglass" found on drawing. But dust from fiberglass isn't it dangerous for loudspeakers ?
It's dangerous for humans, not speakers sorry, I couldn't resist. You don't have to use fiberglass, there are alternatives. Rockwool, denim, etc.
Can be if there's little/no airspace behind the driver, so loosely covering it with cheese cloth allows packing open weave insulation completely around it, though really dense cotton such as Denim Jeans needs to allow some room for it to 'breathe': Altec Heathkit legato 2-15 inch horn & driver
GM
Indeed! Though like Simplex, Heathkit, Urei, etc., custom systems not being a part of the core Altec, I don't include them, but if you or anyone knows for sure that Altec manufactured any of these type systems, then will include them as appropriate in the future.
GM
- Altec Lansing
