phase splitter issue
Comments are of course welcomed.
Now 55th year as a bench oldtimer, ..Many of us have always known about the cathodyne deficiencies and really they are slight; below unity gain, dissimiliar noise and unequal output impedances esp at higher frequencies often dominated by next stage loading Cin; the latter often contributes to higher power amp thd at the top end freq.. The classic bathtub THD curve cannot all be blamed on the output transformer but with unequal driving signals it doesn't help.
I use the cathodyne at its best when feeding into high impedance diff driver stage; Williamson + GEC do it well in their KT66-15/30W amp stages which with self balancing common cathode diff drivers nicely camouflages any cathodyne's shortcomings.
IMO the cathodyne should really be modeled with a diff driver stage where minimalist but consistent input loading takes place. The result is what I would anticipate, symmetry couldn't be better. By sine wave observing (scoping) the common cathode connection on the diff driver one should see the f2 component which has local feedback with the grid resistors, that any mis-amplitude occurring is clearly visible and is automatically corrected at the driver anodes. One has to be content with one's lot, simplicity and couldn't ask for more !
Add global NFB; Viva, all is corrected. Anything wrong in that ?
rich
Rich, I agree with your "cathodyne at its best" and "with a diff driver stage where minimalist but consistent input loading takes place" comments.
That being said, I'm not arguing for or against its use in any particular situation. I'm just trying to straighten out some misconceptions presented in the past about the circuit's characteristics.
The problems of the traditional “floating” Cathodyne Model are evident without invoking simulators or resorting to analyses based on Kirchhoff’s laws.
It’s obvious that the Model ignores the question of power supply rejection; to it, Cathodynes with 10mV and 10V B+ ripples are identical. Also ignored are the effects of the value of the (matched anode and cathode) loads – 10 kOhm circuits are indistinguishable from 10 ohm ones. Of course, bench tests easily reveal both types of differences.
The Model is like a transformer winding. Each specifies a pair of terminal voltages with respect to that of a third terminal to which the pair is connected. For the winding, that terminal is its center tap; for the Model, it’s an imaginary “Common” terminal.
Just as with a transformer, without a ground connection, the Model cannot specify voltages with respect to ground. (As such, the Model befuddles simulators – see attached.) This is a real problem for a circuit whose purpose is to drive an output stage which is controlled by its ground-referenced grid voltages (its cathodes are typically AC-grounded), not by its inter-grid voltage difference (as specified by the Model.) As if that were not enough, in the absence of ground, there is no closed path through which high signal level output stage grid current can flow. An acceptable model must have connections to ground.
In summary, the Model disregards B+ supply noise, is insensitive to (matched pair anode and cathode) loading, does not specify the signals which control the output stage, and doesn’t support the flow of that stage’s grid current under high signal level conditions. A different model is required if these unfortunate deficiencies are to be addressed.
  • No_gnd.asc
    No_gnd.asc
There is always a ground, the anode and cathode don't fload, they are connected to the supply.And the supply has a connection to the load (output stage) and is bypassed to have both ends ad AC ground level.
Mona
The thumbnail I provided was not my own Model; it was copied from a Linear Audio article by Stuart Yaniger and received a favorable review from Burkhard Vogel.
In general, I agree with your comments. Although I do not oppose combining the two supplies into one and eliminating "Common", neither do I see that it solves anything. And the ground you added to your thumbnail means that there is no signal at the cathode. Bench tests will show this to be a problem.
Without a valid connection to ground, your thumbnail addresses none of the problems I listed regarding the thumbnail I posted.
Simulate?
Why?
Build a concertina splitter. Connect the splitter to the working output stage control grids (a working amp, preferably with any global negative feedback disabled).
Now, use two probes: 10X, 10Meg, about 5 to 15pf, and a 2 channel scope. Set the scope to AC couple on both channels.
Check that the probes and channels have both matched gain and matched frequency response by putting them both on a square wave, and observing the trace matching. Adjust the probe(s) compensation if it is needed.
Drive the splitter with a 1kHz sine wave. Connect the probes to the cathode and plate of the splitter. Check the phase and gain match.
You may choose to use the Invert function on one channel.
Drive the splitter with a 20kHz sine wave. Connect the probes to the cathode and plate of the splitter. Check the phase and gain match.
(do not drive the splitter so hard that it has grid current; And be sure that the filament is powered by a floating supply (Very Low capacitance to ground). A 6V battery will work.
Now you will know what you get on your exact amp circuit.
No simulation software.
Report back to us with what you got, Please.
Occasionally measurements do not lie.
To assemble a new circuit, it is highly desirable to have an understanding of the effects that components of various values will have on circuit performance. Guided by this, performance is confirmed by bench measurements. Without such an understanding, you could be modifying your circuit over and over, hoping to achieve the results you desire without ever knowing if it is even possible to do so.
6A3sUMMER might prefer to ignore the guidance afforded by models, but others will benefit by making use of the information they provide. A good model and a bench test: each has its place in the process of creating a new circuit.
The purpose of my earlier posts was to disclose the limitations and flaws of a certain popular model and point out that there is an alternative which corrects those problems and improves its accuracy.
Ketje, as I'm sure you've read, I am no fan of this model. But your Vg is the eg in the .param statement of what I posted. V_term, the voltage of each source, is set by another .param statement to be u eg / (u + 2), where u is the triode mu. In my view, the model makes some sense, but it still should be rejected for the reasons I've posted.
1. Except for drawing grid current, grid to plate capacitive current versus grid to cathode capacitance currents, and filament to cathode capacitive and filament to cathode leakage currents . . .
Then, the current change in the cathode circuit is exactly the same as the current change in the plate circuit.
2. That is true, no matter what the cathode impedance is versus what the plate impedance is (but only if you use identical cathode and plate resistors, identical coupling caps, and identical next stage grid resistances to ground).
The balance of the concertina is very very very good if you pay attention to # 1. and # 2. above.
Well, even given that, I still am not a fan of the concertina.
So I defend the concertina, but do not use the concertina.
