Mega midbass straight horn 139dB
re: compound horn - - you can tweak this crude attempt to see what might be done
When I built my 80Hz midbass horns I modelled a fully curved sides / straight conical hypex versus 'stepped' curved sides / straight conical hypex and it made no difference at all.
It makes it a lot easier to build.
Just to illustrate the compound horns I played with before I found the super planar. Both are simulated as compound horns (which might not be ideal for the SP, but it seems to get similar results as the official hornresp models). Conical or exponential does not make much difference in these sizes. These were just concepts, the models would require some tuning. Grey is the non-expanding version. The expanding / dual horn seems to be smoother, but ends up as a larger box. It seems to fit my goal so far - 90 % of performance in a smaller box.
If you have space for them, the good old front loaded horns are the best, no doubt about that. I tend to think that a curved side is not really necessary - John Inlow's wonderful 8PE21 midbass horn is stepped and so is the Summer Rain by Joseph Crowe - and their intended range is higher.
Back in the day Heil had a mid bass box looking like a double Klipsch LaScala.
With two 101dB/w drivers you get +6dB for two drivers and +6dB for a horn in it's operating range = no need to pad a single mid range driver.
I witnessed the James Gang in the early 70's with these. They didn't have/need subs.🙂
Sorry turk 182 for the late reply, yes - before the internet.
I hope you still have interest! let me know I can scan all pages and to kipman725 some scans of the 2 Heil pamphlets I have from the 70s.
Turning the simulations into reality
I have worked out how to generate the horn shape in Autodesk Inventor. To be able to do this you need a CAD package that supports 3D parametric curves. See the attached document. I have also included .ipt file for my horn which will import into fusion.
attachment.php
*squareToRectHorn.zip includes a load of calculations for the hornprofile that might be useful
very interesting that the separate HF horn is preferred over the coaxial as I have heard this view from other people as well. These systems are actual quite close to my plans. However instead of the horns been ground stacked they will all be flown on a giant frame.
System calculations
I have done some basic sums to calculate the limiting factors of the system assuming that the spectrum of what we want to play is that of pink noise. Everything based on continuous ratings.
Speakers:
20 - 100: TBD sub system
100 - 500: this horn
500 - 3000: M200 on TBD horn
3000 - 20,000 Eminence N151M-8 on TBD horn
attachment.php
Adjusting so that the M200 is the limiting factor (ha not much of a limit) we will need a sub system capable of 142dB/1m @20Hz equivalent per side or in a mono stack 149dB/1m @20Hz. Considering the cost of that and the need to get it into a van that will probably have to be scaled back a bit...
Drivers arrived, magnets are huge as you would expect.
attachment.php
CAD is going well, horn is probably going to be made from mixture of ply wood thickness with aluminium bracing.
The low end is to some extent dependent on how the current crisis goes, until we have some idea of that we can't go ahead.
Low end will be front loaded horns to match the rest of the system so no port issues, will probably target 30Hz -3dB which should be achievable by 4-6 18" FLH. Mouths will be undersized and they will split into several parts to facilitate transport. It will all have to fit into a LWB transit. Probably on the first time the system is used it will be in a smaller club so our existing subwoofers will be enough.
The Terrahorn design gives some idea of what can be done with a big FLH:
The Terrahorn
Our system only needs to sub to play to 100 Hz, this allows simpler construction. We would also go with a single fold so the subs will be giant L shapes.
For amps I am probably developing my own high powered plate amps considering the expertise I have in power electronics (I have built something like a 100 kW class D amplifier before) and the amount of free time I have now. They should to ~10kW into 8 ohms burst.
