RJM Audio Emerald Phono Stage Help Desk
Well that was fun, 1st part done, populated two boards.
Used a square 2.2µF capacitor for neatness. Doubt I'll notice difference
KEMET Part Number: R60QW42205030KR60, Film, Metallized Polyester, Automotive Grade, 2.2 uF, 10%, 1000 VDC, 85°C, Lead Spacing = 37.5mm
"Typical applications include blocking, coupling, decoupling, bypassing and interference suppression in low voltage applications"
I have some audio ones as well to try/compare. do let me know if these are totally unsuitable and/or others that are square
I had to bend the pins for 2 of the Nichicon KZ Muse 100µF capacitators as per photo 2 so they fitted properly
Enclosure layout
I have found a nice sized box(whd 215x55x308 external, 203.5x48x297 internal), not ideal to have transformer in same box but is neater. I worry about mains hum, so....
Two choices now, Put Transformer furthest away from the rear and the mains input, and hence shortest phono connections or vice versa?
picture is where the transformer is furthest away, putting phonos on same back panel as the mains input.
@keland
A long thin chassis will always present this dilemma. I recommend to keep the standard position of the connectors in the back, bringing the AC line from the rear socket to a front power threading the wire down the side of the chassis and keeping the transformer and diodes in the front, with the PCBs at the rear close to the input RCA jacks. A metal divider or box enclosing separating the AC power line from the PCB may help with noise pickup, but a lot of the coupling is inductive, so it won't be a definitive solution.
@AnthonyA
R2 = 400 ohms, R3 = 15 ohms Your gain setting is on the high side, circuit noise will increase proportionately.
I finally managed to finish my Emerald phono stage yesterday afternoon. It's a bit of a revelation tbh! My Benz Wood which I though was worn out sounds ace ( there's a joke in there somewhere ) I'll post a few pics as soon as I get the chance.
A big thank you Richard.
My Emerald boards are ready for power up. I did not find instructions on how to setup the Emerald phono stage boards from powering them up and biasing if any required. Also not sure what is the purpose of that trimmer on each of the mono board.
Can someone let me know the instructions of powering them up from the bridge rectifiers where I have a +/-12VDC. What should I check if the boards are working fine before I connect to the turntable.
