Andrew,
Mooly has linked the layout in post 1 as the working layout and also here is the post by Marc on his build.
My MOSFET amplifier designed for music.
to Friedmule
For your search.
The 150p also called "styroflex" or choose FKP2 like this:
FKP2D001501D00HSSD WIMA - Kondensator: Polypropylen | 150pF; 5mm; +-2,5%; 4,5x6x7,2mm; 1kV/μs; FKP2-150P/100 | TME - Elektronik Bauteile
That's what i use.
The 22p is also called "silver mica" or take a KERKO 500V disc capacitor.
Standard :: Silver Mica :: Capacitors :: Passive Components :: Electronic Parts :: Banzai Music GmbH
Mouser or Digi Key should also have stocked them.
Glimmer- und PTFE-Kondensatoren | Kondensatoren | DigiKey
To Mooly and interested it was #719
where prasi shared the schematic and layout with paralleled R9-680k to 22p.
For your search.
That's what i use.
Mooly that is additional/optional added FB Resistor.
Don't remind correctly who has done it.
Yes, I vaguely remember now. It could have been AKSA that mentioned it.
I tried it. It was a bit too warm/soft sounding for my tastes, but worth a try.
Hello Mooly
greetings rough pcb for testing its prasi design
warm regards
Andrew
Andrew,
I havent looked at the layout in detail, but I suggest to keep the original feedback take off point as per my design. There is a specific reason for that to reduce THD.
Make an extra drill in the layout and use a wire to connect.
regards
Prasi
P.S., if you look at my design, its single sided only but with repeat traces on top. and feedback takeoff can be a wire. just 2c.
FriedMule,
make your homework before asking. post #1 gives the details. i have it posted here.
you can easily import gerbers into sprint layout and make adjustments as per your components.
Yes sorry for that, but I have to admit I did not remember that post. I did read most of the 1000 posts but did not remember that you had been so kind to share your files.
Edit: it looks like it's the gerber files, or am I missing something?
I was looking for the project files
- My MOSFET amplifier designed for music
