AKSA's Lender Preamp with 40Vpp Output
Nice work, Do. I see a pink Takman CF feedback resistor? Nice!
Yep, those are the Takman! 🙂
Just a quick question... With a 1.1V and 10K sine wave, the output measure roughly 19.5Vpp before the upper part of the sine wave starts squaring. Is this normal I'm not reaching close to 40Vpp? Just want to make sure I can drive the Mofo with plenty of power.
Do
Hi Do,
Sorry you are having troubles. That doesn’t sound right. You might have an error somewhere on the circuit. Early clipping like that sounds like maybe the resistors on the input LTP are off and the midpoint DC voltage is far from 1/2Vcc. Please check the DC voltage upstream of the output coupler. If you are clipping at 20Vpp, suggests your DC there is not 24v (1/2 of 48v) but maybe about 34v. Please check your PCB to make sure you have the correct version - I may have sent you v1 boards by mistake, which has a silkscreen typo (R102/103 we’re swapped) for the two resistors on the voltage divider that sets the input BJT bias voltage. The 33k resistor should be going to the base of Q1. If you have 10k there and 33k as the 9k1/33k divider you will have an elevated DC midpoint of 33/(33+9.1)x48v=37.6v instead of circa 24.5v. This is detailed in the errata list in Post 1 of the GB thread here:
AKSA's Lender Preamp with 40Vpp Ouput GB
650412d1512862009-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-smt-schematic-v2-png
Can you provide an O-scope shot like this one? This of course shows 40Vpp as demonstration that this preamp can do that.
644607d1510165924-aksas-lender-preamp-40vpp-output-40vpp-oscope-screenshot-jpg
Btw, MOFO is about a 12wrms amp or needs 28Vpp to hit clipping on the amp. 40Vpp is to get to 25wrms at 8ohms.
If I accidentally sent you the wrong PCBs, please accept my apologies. I’ll send you a new set of v2’s to have for the future.
Hi Do,
It has been about 3 years since we last worked on these MELF boards so I am a bit fuzzy on the whole thing myself. I am looking at the REV001 board under a mircroscope and see that the R102 correctly goes to the base of the input LTP and R103 goes to ground. R102 needs to be 33k and R102 needs to be 10k. So can you check your board to see which resistors you have at R102 and R103? Here is a graphic to show you.
attachment.php
Here is the schematic:
I can't quite make out the colors (MELF resistors have terrible color contrast with the brown body, and the red is almost brown rather than red, but black is clearly black) but it looks like you may have 10k and 33k resistors swapped by accident:
attachment.php
Hi Do,
The BOM is indeed wrong. R102 needs to be 33k and R103 needs to be 10k, per the schematic. When in doubt, the schemtic overules the BOM. 🙂
Sorry about that - I need to put a note in Post 1 about this error.
Hope it is not too much of a pain to swap - some hot air and tweezers and you should be good to go.
X
Hi Do,
X
Hi X,i think,if memory serve well,that is another error on the main board this time.
R141=10k,not 220R.
Yes. And that is well documented on the errata list on post 1 of the GB thread:
Alert - error on main PCB. R141 Should be 10k not 220R.
Alert - error on main PCB diode V141 should be standard 1N400X not breakdown or zener.
Revised BOM for MB (8-pin connector was incorrect), file here:
Error 404 - Forum Page Missing
Mainboard schematic looks like this (note R141 is 10k not 220R):
