Rockford 800.2
Hi
I fixed power supply. It had a mosfet bad. Now amp comes on a d has all the voltages. Signal is good until R201. After that the signal is very weak on outputs. Tested all transistors but everything looks good. Does it have mute signal any where.
One channel is pulling current mostly irf9640 0.1 ohm resistor is have 6.8 millions. On one resistor when I remove that mosfet other resistor now having 6.8 to 7 milliohms. I removed all 9640 except one and this mosfet resistor also having same value. Other side channel only has 0.2milliohm. Bias pot turned all to anti clock side.
See attached.
List which FETs are now out of the circuit and which FET has high current across it's 0.1 ohm resistor with the bias fully CCW.
Out of circuit fets
Q215 Q214 Q212 Q211
Q220 Q219 Q217 Q216
Current across 0.1 resistors
Q213. 5.7mV
Q218. 5.7mV
Q315. 1.2mV
Q314. 2.3mV
Q313. 1.0mg
Q312. 1.1mV
Q311. 1.2mV
Q320. 0.5mV
Q319. 4.1mV
Q318. 0.6mV
Q317. 0.8mV
Q316. 0.6mV
He is asking what the voltage is now across the source resistor for the fet you pulled out (Q319)
The 300 series parts are marked on the board for example R301,R355 ect if you look at the silk screen printing on the board 1 channel all the resistors diodes ect are marked 3xx and the other channel are marked 2xx
