I have a MiniDSP streamer mulitchannel USB to I2S board, so this could be used with the STARpure DAC and a coventional PCM dac to make 4- channels, I guess. Then there will be no need for a controller for the CT7302 in 4-channels, right?
Yes, you can use as input a MiniDSP streamer multichannel but the CT7302 chip need a controller to select the configuration, input, pcm to dsd convertion and other parmeters.
Thaks, but I do not need a 4-channel controller for the CT7302 only the standart 2-channel controller, as the CT7302 only controls the two of the channels, right?
Yes, you can use 2 different DAC for the 2 different I2S output but I don't know if there are problems of sincronization.I have a MiniDSP streamer mulitchannel USB to I2S board, so this could be used with the STARpure DAC and a coventional PCM dac to make 4- channels, I guess. Then there will be no need for a controller for the CT7302 in 4-channels, right?
No problems with that, Audiolense will take care of any timing issues between sub and arrays. Still my question is.: I only need a controller for the CT7302 in 2 channels, when I only use it in two of the channels anway right?
The controler module is connected to one STAR DAC DSC module in normal stereo configuration.
If you want to use 2 x STAR DAC DSC modules the controller can be modified.
Nothing much happening here. I guess I have to try the evaluation board CT7302 EVM --c from Comtrue Inc. to be able to go on with my project.
HI!
We are still working on it!
quanghao
ThanksHI!
quanghao
Do you have a time horizon for the completion of the baords.
And what is it exactly you are working on? The complete Star Pure DAC? Or a separate board for the CT7302 ?
But it has already been made, with controller and all. I am not sur what is missing before it could be available.Perhaps understandable if it takes awhile. CT7302 has about one hundred fifty I2C registers 😱
hi!
yes: Star Pure DAC, i was complete !
now i working about your want:
Only CT7302 board -out i2S ( no DCS) with control!
thank you advice!
qaunghao
I hope you mean out only I2S AND DSD - but without the DSC dac. 😉hi!
thank you advice!
qaunghao
Do you have any idea to when this is ready?
And is the Star Pure DAC ready to buy anywhere?
hi!
thank you advice!
qaunghao
I would be really interested in this board.
Could we have I2S input as well as output? This would allow people use to their own transports like USB to I2S boards.
I forgot to say: That sounds wonderful. Thank you very much Quanghao!!😀😎hi!
thank you advice!
qaunghao
hi!
thank you advice!
qaunghao
Price? Availability?
Are you able to provide any details should I wish to try this? is it a simple modification or extensive?
Cheers
bs
Hi qaunghao, what resistors are used Sumiko RG 0.1%?
What size 1206?
Cheers
bs
Hi !
I use this:Vishay MMA0204 -1206
Here are some pictures of Star pure Dsd DAC.
1- Star pure Dsd DAC board
2- Star pure Dsd DAC output board
3- Control circuit board.
4- Remote control
5- A full set of Star pure Dsd DAC
thanks
4- Remote control
thanks
- Digital Line Level
- STAR Pure DSD DAC-Signalyst New
