STAR Pure DSD DAC-Signalyst New
I have a MiniDSP streamer mulitchannel USB to I2S board, so this could be used with the STARpure DAC and a coventional PCM dac to make 4- channels, I guess. Then there will be no need for a controller for the CT7302 in 4-channels, right?
Yes, you can use as input a MiniDSP streamer multichannel but the CT7302 chip need a controller to select the configuration, input, pcm to dsd convertion and other parmeters.
No problems with that, Audiolense will take care of any timing issues between sub and arrays. Still my question is.: I only need a controller for the CT7302 in 2 channels, when I only use it in two of the channels anway right?
The controler module is connected to one STAR DAC DSC module in normal stereo configuration.
If you want to use 2 x STAR DAC DSC modules the controller can be modified.
Do you have a time horizon for the completion of the baords.
And what is it exactly you are working on? The complete Star Pure DAC? Or a separate board for the CT7302 ?
hi!
yes: Star Pure DAC, i was complete !
now i working about your want:
Only CT7302 board -out i2S ( no DCS) with control!
thank you advice!
qaunghao
Here are some pictures of Star pure Dsd DAC.
1- Star pure Dsd DAC board
2- Star pure Dsd DAC output board
3- Control circuit board.
4- Remote control
5- A full set of Star pure Dsd DAC
thanks
