A guide to building the Pass F4 amplifier
Zen Mod I needed information, to weaken the amplifier (I need only 7-8W) what should I change compared to the original scheme?
- remove two pair of output device?
-descrease the power supply voltage?
-change the value of bias setting?
-change the value of some component?
Precise that I currently have an E88CC SRPP Preamp with a gain of about 28-29dB and a pair of heatsinks of the dimensions of 35x125x250 mm.
Thank you in advance
Hello sergiog
(sorry my autocorrection put it wrong)
I just read this post of yours. Having the same issue, I wanted to ask if you followed this path and did build a "2/3F4"?
How di it work?
How did you do it?
thank you!
david
BUILD!
Ahh same trap again!
I should come to terms with f4‘d concept and just build one. [emoji4]
Everything but the chassis is here. (probably 1 or 2 parts glitches and Salas' B1 waiting for me)
At the moment, I'm trying to work out (like, calculate 😕) the heat-sink-requirements. Looking for power-dissipation per transistor etc etc...
6L6, I read that you use cardas quad eutectic. Do you use their Rosin Flux Paste too? Because I do, and it's quite messy...
I like the Cardas Quad. I have not used their flux.
Heatsink requirement is easy - 4U deluxe chassis. 😀
I've used their flux and while nice I don't think its needed for most applications. On top of that its a pain to clean the excess which can be a lot even when using a small dab. Been using the Cardas solder though for a few years and its great. I use it and along with kester solder
Hello sergiog
How di it work?
How did you do it?
thank you!
david
For this idea, why not a Mofo build with lower voltage? (I don't know what low power Mofo sounds or measures btw, just the first thing to jump in to my head.)
To get 7-8w max out of my F4, I adjusted B+, the primary (5k to 2.5k) and secondary connection (4k to 16k) of my 2a3 SE amp and drove it with that.
jervill
Nothing. Nothing speaks against building a Mofo. Quite the opposite. But only _after_ F4 🙂
I am getting a handle on most of the parts to order, except the LEDs.
There are hundreds listed on Digikey. My search didn't turn up
any parameters to look for. If someone could list the important specs
(or part number) I would be grateful. Blue would be my preference.
